How to add Komplete 8 Ultimate into Pro Tools 10 LE
I've goolged it and nothing has come up. Only thing I have seen is you have to buy a program that converts VST plugins into RTAS.
Is that the only way? Thx in advance! |
Re: How to add Komplete 8 Ultimate into Pro Tools 10 LE
Komplete 8 has RTAS versions of everything. You don't need a converter, just run the installer.
Dave Marsden UK |
Probably the reason you don't get any search results is because you called it Protools 10 LE. There is not such thing. It is just Protools 10 or Protools 10 HD new. The LE naming convention ended at Protools 8.x.
And as mentioned above, Komplete and Komplete Ultimate comes in RTAS format so there is no need for a VST wrapper utility to use it with Protools. And yes, it works with Protools 10.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Thats good news. Thanks for your help. :)
Komplete 8 Ultimate | tystick420 | Pro Tools 11 | 10 | 07-07-2013 02:28 PM |
Komplete Ultimate Hard Drive and Pro Tools Questions. | PatriotsBiker | Virtual Instruments | 26 | 10-14-2012 09:54 AM |
Considering KOMPLETE 8 Ultimate but $1000?? | wearetheniceguys.com | Virtual Instruments | 3 | 01-22-2012 08:40 AM |
Komplete 8 Ultimate | paldry | macOS | 1 | 12-06-2011 07:42 PM |
