S6L fiber vs ethercon
We're using 150m fibers for connecting the stage rack(s) to the foh-console and we've used ethercon to connect everything else in the system: control surface to engines, mon- engine to stage racks and linking stage racks, so all the short cables. Is there a reason they should be changed to fiber or is everything fine like this? Everything has worked without any glitches but just wanted to check. Ilkka
Music business is serious business. |
Re: S6L fiber vs ethercon
I don't think you need to change anything. Fiber is a solution for long distances, otherwise good wire is ok.
Totally fine. A shared media scenario is no problem
Hugo Larin, VENUS | S6L ACSR |
it's A-Okay to use fiber for some portions of the system and ethernet for others, I imagine that in most cases console to engine will be ethernet run, and the run to stage racks may be fiber.
CAT to Fiber for S3L | pmueller | VENUE Live Sound Systems | 0 | 01-18-2014 07:23 AM |
Best Solution for Fiber | DHS | Pro Tools TDM Systems (Mac) | 0 | 11-13-2009 07:56 AM |
Remote 002 via fiber OPTIC, not fiber channel... | Kelly M. Pieklo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-18-2005 09:47 AM |
Fiber SAN | loopengine | Pro Tools TDM Systems (Mac) | 3 | 01-16-2003 11:26 AM |
Fiber Questions | E-money | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-05-2000 12:09 AM |
