DP and spinning beachball
In an effort to reduce latency with virtual instruments in DP, we tried lowering buffer settings to 128 or 256, but when we do this we get the spinning beachball. So we're stuck at 512 which is too slow for live playing of instruments.
Oddly enough, if we switch from Digi HD hardware to the G5's internal audio, we can lower the buffer down to 64! Anyone know what causes this? DP 4.5, G5, 2 Ghz, 2.5 GB Ram, PT HD2 |
Re: DP and spinning beachball
Have you done the upgrade to DP4.52 (released yesterday)? It's supposed to handle virtual instruments a lot better. I have only played with it a bit, but it seemed much more responsive with Mach 5 than the first DP 4.5 release on my Mix3 system.
rcm
Save early and often! (or once a day whether you need to or not...) |
Thanks Traks. I'll check it out. Anyone else re: the spinning ball? What does this generally mean. RAM allocation problem?
PT 10 won't boot .... spinning beachball | boogiemotel | macOS | 1 | 12-22-2011 10:48 AM |
Spinning beachball ? | albee1952 | Pro Tools TDM Systems (Mac) | 10 | 03-31-2010 12:35 PM |
spinning beachball when I hit record | beefstew | Pro Tools TDM Systems (Mac) | 3 | 04-24-2007 01:40 AM |
Spinning BeachBall After Recording | colinx1 | Pro Tools TDM Systems (Mac) | 8 | 01-19-2005 07:11 PM |
Spinning Beachball..... | dropking | Pro Tools TDM Systems (Mac) | 10 | 10-09-2004 11:09 PM |
