Strike upgrade
Hello,
I've had problems with Strike for several months now: Like many others, I get the dreaded "content not found please run the set content location application". I'm running PT 9.0.6 with a Digi 002R. At the suggestion of someone else on this forum, I tried removing Strike so that I could reinstall. I searched for everything that related to the plug-in, deleted it, emptied trash and re-started. But every time I tried to reinstall, I got an error message that a later version of the software was already installed on this machine. I don't know what it's still "finding". I just tonight noticed a thread that was updated on March 12, with a link that *may* solve that problem, so I downloaded the update. But of course when I launch PT and try to add Strike, the system can't find it since I deleted the original application. And I can't put it back, because the computer thinks it's already there! Here's my question (finally): If I spring for the $99 Strike upgrade, do you think it would fix all this, besides adding the new samples and grooves? If so, it would totally be worth it. My fear is that it'll think I'm not technically *upgrading*, since Strike is no longer installed. Thank you in advance for any assistance. Would LOVE to finally use the program again! --- Billy |
Re: Strike upgrade
Personally I would hold off upgrading and focus on a current compatible system. Is your OS compatible with the current installed Pro Tools version? Have you tried repairing the Strike installation by running the installer again?
Aaron Mulqueen - 001 HD Native |
Re: Strike upgrade
Thanks, Aaron. Everything is most definitely compatible within my system, it's just that if I *do* to to re-install, I receive the error that Strike is already on my system in a newer version --- whereas it's actually no longer installed at all --- so it's an icky catch-22. I'm completely at a loss...
Re: Strike upgrade
So the Strike Installer will not Repair the installation? Hmmm... Restore Points? Clones? Images? What Operating System are you using?
Re: Strike upgrade
is this on windows or osx?
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Re: Strike upgrade
Thanks for writing back, Aaron and Benoni; my apologies for taking a few days to respond.
I'm using an iMac G5 3.06 GHz Intel Core i3, with 8 GB of RAM. Version 10.6.8 of OS X. When I insert the first (of 2) Install discs, I get to the first screen, "Welcome to the Digidesign Strike Plug-In Installer", no problem. I get through all the steps in the Installer, up to and including "Select a Destination" to install Strike. But once I click on my internal hard drive, there's an error on that page I cannot get past: Digidesign Strike Plug-In can't be installed on this disk. A newer version of this software already exists on this disk. (I have screenshots, but when I tried pasting them into this box, they came out garbled in the preview) If I click on my external drive, I receive the message that: Digidesign Strike Plug-In can't be installed on this disk. You can only install this software on the disk that is running Mac OS X. I cannot figure out where I might have "pieces" of Strike laying around that the Installer disc is finding each time. I'm pretty sure that if I could delete all traces of Strike from my machine, I'd be good to go. Thank you again for your input. I look forward to any suggestions. --- Billy |
Re: Strike upgrade
Does Strike show up as still being installed?
What if you check any/all Avid and Digidesign folders? is there any trace of Strike there? Have you tried a 3rd party application like Ccleaner (for Mac) and check if Strike shows up as being installed? You can also repair permissions with Ccleaner (for Mac) http://www.piriform.com/mac/ccleaner Does your External drive contain a backup or something that may contain some Strike related files? Maybe try unplugging the External and see if Strike will install.
Re: Strike upgrade
Thanks, Benoni! Strike most definitely does not show up as being installed. In fact, if I try to open an old session with a Strike track on it, I get the error that "The following plug-ins were made inactive because they could not be found in the plug-ins folder: Strike (1)"
I've checked all the folders that I thought might contain a "trace" of Strike, and found nothing. I have not tried any third-party platforms; I guess my unfamiliarity with those programs makes me a bit nervous. But I'll try Ccleaner this weekend if you think it might help. And there may be some Strike-related files on an external drive (although there really shouldn't be), so I'll try unplugging that and trying again. Again, much appreciated for the help, Benoni. |
Re: Strike upgrade
You will most likely have the problem EVERYTIME you upgrade or upgrade Strike. I had it every time.
Strike 1.5 -> 2 upgrade | guym | Virtual Instruments | 12 | 06-27-2013 03:03 AM |
Strike upgrade | billy101 | Virtual Instruments | 2 | 04-14-2012 12:03 PM |
Strike 1.5 upgrade | bscism | Virtual Instruments | 6 | 11-29-2011 07:26 PM |
Strike upgrade?? | j.thomas | Virtual Instruments | 0 | 10-19-2011 01:22 AM |
Should I upgrade 6.7 to 7.4? Want to use Strike ... | TDub | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-22-2008 05:22 PM |
