  #21
Old 11-05-2011, 07:49 AM
agill711 agill711 is offline
Default Re: wont load
ok i spent 1.5 hours with sweetwater tech support, who by the way called avid and they gave him a list of other things to try besides what was in there knowledge base. we tried asio4all and still didnt load, we turned of virus protection. went through all the win7 optimize guide. removed all the plugins. thought might be the rewire from reason 6 and removed rewire. nothing worked.
next i used my support code and talked to him and he checked everything the sweetwater guy checked. he said that it looked like the new disk cache that hold the audio in memory instead of streaming it off the hard drive was not starting or allocating memory. this feature was not in 9 so thats why 9 works with no problem. maybe they need to have that as an option that you can turn on and off. i dont have any problems with audio streaming from my audio hard drive. so he told me that he would send it up to a higher tech level.
hey directx are you using a pc or mac?
Amd Phenom II x6 1055T 2.8GHz
GIGABYTE GA-970A-UD3 AM3+
8 Gig DDR2 1066
Win 7 64bit Pro
ProTools 9.05
Mbox 3 Pro
  #22
Old 11-05-2011, 08:01 AM
Directx Directx is offline
Hi Agill711. Thanks for all the info. I basically went through the same steps with Avid tech support. Same results. There is obviously an issue with certain systems and the new disk cache feature. I'm running Win 7 x64. I have PT10HD running fine on my desktop (same OS) but it won't budge past this error -9514 on my HP laptop. If you make any progress please post an update and I’ll do the same.
  #23
Old 11-05-2011, 09:06 AM
i just loaded it on my win7 64bit laptop and got the same message.
8 Gig DDR2 1066
Win 7 64bit Pro
ProTools 9.05
Mbox 3 Pro
  #24
Old 11-05-2011, 09:47 AM
dts350z dts350z is offline
Same issue here. PT 10 hangs on AirChorus. If I move that to unused plugins then it hangs on the next one.
Holding down the shift key does not prevent plugins from loading.
  #25
Old 11-05-2011, 12:58 PM
i removed all the plug ins and it still didnt work. do you have reason 6 64bit or
32bit loaded
8 Gig DDR2 1066
Win 7 64bit Pro
ProTools 9.05
Mbox 3 Pro
  #26
Old 11-05-2011, 02:38 PM
I got it to work on a win 7 64 bit laptop where I didn't have any plugins installed. But my main machine (also win 7 32 bit) still won't load it even if I remove all 3rd party plugins or even all plugins.
I uninstalled PT and reinstalled, no joy. Now instead of hanging on AirChorus it crashes when trying to load AirChorus.
Captured this in visual studio:
snip
'ProTools.exe': Loaded 'C:\Windows\SysWOW64\davhlpr.dll'
'ProTools.exe': Loaded 'C:\Windows\SysWOW64\wkscli.dll'
'ProTools.exe': Loaded 'C:\Windows\SysWOW64\cscapi.dll'
'ProTools.exe': Loaded 'C:\Windows\SysWOW64\netutils.dll'
'ProTools.exe': Loaded 'C:\Program Files (x86)\Common Files\Digidesign\DAE\Plug-Ins\AIRChorus.dpm', Binary was not built with debug information.
'ProTools.exe': Loaded 'C:\Users\Glenn\AppData\Local\Temp\PILBA2B.tmp', Binary was not built with debug information.
'ProTools.exe': Loaded 'C:\Windows\SysWOW64\devrtl.dll'
'ProTools.exe': Loaded 'C:\Windows\SysWOW64\pcwum.dll'
The thread 'Win32 Thread' (0x131c) has exited with code 0 (0x0).
Unhandled exception at 0x76eeb9bc in ProTools.exe: Microsoft C++ exception: PCErrWin at memory location 0x0018bcac..
The thread 'Win32 Thread' (0x25c) has exited with code 0 (0x0).
The thread 'Win32 Thread' (0xb40) has exited with code 0 (0x0).
The thread 'Win32 Thread' (0xf7c) has exited with code 0 (0x0).
The thread 'Win32 Thread' (0x1004) has exited with code 0 (0x0).
The thread 'Win32 Thread' (0x4b8) has exited with code 0 (0x0).
The thread 'Win32 Thread' (0x2a8) has exited with code 0 (0x0).
The thread 'Win32 Thread' (0x2f8) has exited with code 0 (0x0).
The thread 'Win32 Thread' (0x12d4) has exited with code 0 (0x0).
The thread 'Win32 Thread' (0xe1c) has exited with code 0 (0x0).
The thread 'Win32 Thread' (0x1020) has exited with code 0 (0x0).
The thread 'Win32 Thread' (0xc64) has exited with code 0 (0x0).
The thread 'Win32 Thread' (0xbbc) has exited with code 0 (0x0).
The thread 'Win32 Thread' (0x1158) has exited with code 0 (0x0).
The thread 'Win32 Thread' (0x3b4) has exited with code 0 (0x0).
The thread 'Win32 Thread' (0xcc4) has exited with code 0 (0x0).
The program '[3196] ProTools.exe: Native' has exited with code 0 (0x0).
and no, I do not have reason on this machine. My audio interface is saffire Pro40 and I aslo have Complete Production Toolkit 2 on both the working and non working computer.
SiSoftware Sandra
Computer
Workgroup : WORKGROUP
Host Name : TheBeast
User : Glenn
Processor
Model : Intel(R) Core(TM)2 Duo CPU E8500 @ 3.16GHz
Speed : 3.16GHz
Cores per Processor : 2 Unit(s)
Type : Dual-Core
Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 Cache : 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing
Computer
Mainboard : Intel DP43TF
BIOS : Intel NBG4310H.86A.0096.2009.0903.1845 09/03/2009
Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 4GB DIMM DDR2
Chipset
Model : Intel P45/P43/G45/G43 DRAM Controller
Front Side Bus Speed : 4x 333MHz (1.33GHz)
Channels : 2
Memory Bus Speed : 2x 400MHz (800MHz)
Memory Module(s)
Memory Module : Kingston 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3)
Video System
Video Adapter : ATI Radeon HD 4300/4500 Series (40 SM4.1 600MHz, 512MB DDR3 800MHz 64-bit, PCIe 2.00 x16)
Graphics Processor
STREAM GP Processor : ATI Radeon HD 4300/4500 Series (40SP 2C 600MHz, 512MB DDR3 800MHz 64-bit)
Storage Devices
Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm) : 2TB (G:)
WDC WD1001FALS-00J7B1 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (C:)
Seagate ST3500418AS (500.1GB, USB2/SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (E:)
Optiarc DVD RW AD-7240S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
IBCN 4LQJC5YNCL (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (F:)
IBCN 4LQJC5YNCL (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (H:)
Logical Storage Devices
Gee (G:) : 2TB (NTFS) @ Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm)
System Reserved : 100MB (NTFS)
Media Backup (E:) : 466GB (NTFS) @ Seagate ST3500418AS (500.1GB, USB2/SATA300, 3.5", 7200rpm, 16MB Cache)
Hard Disk (C:) : 931GB (NTFS) @ WDC WD1001FALS-00J7B1 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache)
Optical Drive (D:) : N/A @ Optiarc DVD RW AD-7240S (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Optical Drive (F:) : N/A @ IBCN 4LQJC5YNCL (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R)
Optical Drive (H:) : N/A @ IBCN 4LQJC5YNCL (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R)
Peripherals
LPC Hub Controller 1 : Intel LPC Interface Controller
LPC Legacy Controller 1 : Winbond W83627DHG
Audio Device : Intel HD Audio Controller
Audio Device : ASUS RV730XT Audio device [Radeon HD 4670]
Serial Port(s) : 1
Disk Controller : Intel 4 port SATA IDE Controller
Disk Controller : Intel 2 port SATA IDE Controller
Disk Controller : Jmicron JMB368 IDE Controller
USB Controller 1 : Intel USB UHCI Controller #4
USB Controller 2 : Intel USB UHCI Controller #5
USB Controller 3 : Intel USB UHCI Controller #6
USB Controller 4 : Intel USB EHCI Controller #2
USB Controller 5 : Intel USB UHCI Controller #1
USB Controller 6 : Intel USB UHCI Controller #2
USB Controller 7 : Intel USB UHCI Controller #3
USB Controller 8 : Intel USB EHCI Controller #1
FireWire/1394 Controller 1 : Intel FW322/323 IEEE1394 OHCI FireWire Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : EPSON WorkForce 600 Series (360x360, Colour)
Scanners and Cameras
Scanner : Microsoft EPSON67AC31 (Scanner, USB)
Network Services
Network Adapter : Intel(R) 82567V-2 Gigabit Network Connection (Ethernet, 1Gbps)
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 3.5
  #27
Old 11-08-2011, 07:49 AM
Mine is loading now.
See enableing DEP in this thread:
http://duc.avid.com/showthread.php?p...66#post1849766
  #28
Old 11-12-2011, 08:18 AM
divedive divedive is offline
Same problem as you guys... won't load... hangs when it tries to load plugins.
I'm wiped out after tinkering around and lurking these forums for days straight...
  #29
Old 11-12-2012, 08:29 PM
ReynaldoPena ReynaldoPena is offline
Originally Posted by DigiTechSupt View Post
Do you possibly have Disk Cache enabled (set to anything other than 'Normal)?
If so - setting it to Normal should resolve the issue.
how do i set the disk cache on normal
Take care brush your hair,
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
iMac (Retina 5K. 27-Inch, 2020)
Processor 3.6 GHz 10-Core Intel Core i9
3.6 GHz Dual-Intel Core i7
16GB ram
AMD Radeon Pro 5700 8GB
Shure SM7B Mic
Pro Tools | Carbon
Komplete Kontrol M32
AKAI Mpk3 Mini
KALI Lp 6 (2)
  #30
Old 11-12-2012, 08:39 PM
TOM@METRO's Avatar
TOM@METRO TOM@METRO is online now
The setup pulldown menu> playback engine> disk playback> cache size> normal.
Keep it on normal unless you have at least 6GB of RAM installed on a 64bit OS.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
8.04 wont load Johnptk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 07-08-2010 03:59 PM
pro tools wont load matt.brack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-25-2010 07:39 PM
structure wont load anthony_dasti Pro Tools M-Powered (Win) 6 10-20-2009 09:26 PM
Help! Pro Tools wont load Istarri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-07-2009 02:00 PM
wont load! (xp) duanebonney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-16-2002 07:25 PM
