Old 12-12-2006, 06:30 AM
tomdiek tomdiek is offline
Default Dithering
Hello,
Could someone explain the process of dithering when you bounce to disk?
Thanks!
Pro Tools 2019.6
iMac (Retina 5K, 27-inch, Late 2015) OS 10.14.6
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
Apogee Symphony MKII Thunderbolt 2X6
Old 12-12-2006, 06:43 AM
mindnoise mindnoise is offline
Default Re: Dithering
HI,
if you dither from 24 to 16bit after bounce or do it manually it´s the same.
here´s an article about the topic from Bob Katz:
http://www.digido.com/modules.php?na...article&sid=14
find out more here:
http://www.theprojectstudiohandbook.com/directory.htm
besides the technical explanations, these sources tell you:
- if dither is good for you depends on the audio material.
e.g. audio with very low or silent audio levels.
- only dither when from going from high to low bit levels 24->16 etc.
- dithering is the very last step before going into duplication.
regs
last: PT11.3.1
Dithering.... JazzyJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-11-2009 01:32 PM
Dithering DOWN.... 98wildcat Pro Tools TDM Systems (Mac) 3 08-27-2007 08:00 PM
Dithering JohnChancey Tips & Tricks 2 01-13-2007 03:27 PM
POW-r 3 Dithering Imagine Pro Tools TDM Systems (Mac) 13 03-06-2005 09:07 AM
Dithering and 48k nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 05-08-2001 11:40 AM
