Flip through Hybrid, Vacuum, Massive Patches on AxiomPro49
Anyone know how to Flip through Hybrid, Vacuum, Massive, Xpand! etc... Patches on an AxiomPro49 With Hyper Control, that could give me a quick Play By Play. I've searched the Manual for ProTools specific SoftSynth Patch changing, and have come up empty.
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
Re: Flip through Hybrid, Vacuum, Massive Patches on AxiomPro49
I believe that functionality is mentioned in the HyperControl for Pro Tools Guide. But anyway, Axiom Pro needs to be in Instrument Mode, so F1 and hold SoftKey 2 and switch up and down using SoftKey 3 and 4.
Aaron Mulqueen - 001 HD Native |
Thanks for your Quick reply Aaron - Ya, I've been through Page 18 on "Instrument Mode" and I can't seem to get F1 to do anything, with the track selected, and the Plugin open and selected.
It looks like it is perpetually in Instrument mode (As the sliders and knobs are mapped to the plugin, and not ProTools Mixer), however F1 is NOT toggling it back to "Mixer Mode" (Which I don't use anyway, as I'm still using a ProControl) But "Softkeys 3 & 4" don't seem to do a thing, when holding Softkey 2 SEE ATTACHED MOVIE HERE
Yeah Hi David, according to your video, which by the way is very helpful, I like, ummm... you need to exit Pro Tools, turn Axiom Pro On then load the Pro Tools Mac Axiom Pro Patch although not necessary, then launch Pro Tools. In Peripherals setup M-Audio Keyboard as the Personality - HyperControl In and Out on Channel 8. If you are lucky there should not be a confection with your ProControl. But now try that procedure again.
Brilliant, you were bang on with the ProControl being a conflict.
I had set up MAudio Keyboard, HyperIn and HyperOut 8Channels in Midi controllers under Peripherals, and still couldn't get it to work... the Video I had shot, I had the ReceiveFrom Dialog set to AxiomHyperIN - and the SendTo - Directly to the Plugin (Vacuum) just to see if I could force it. Nevertheless, after your post, i set it Back, as your instructions, and you were right on the mark, with your prediction that it was the ProControl Conflicting / blocking the HyperControl. As soon as i Killed the ProControl / Unchecked Ethernet, and left the Midi Controller configured as you noted, I'm able to flip Presets as you and the Manual describe. the second I "Add" the ProControl, the AxiomPro 49 acts immediately like it did in my Video. I guess it's one or the other, these two won't live together. Thanks again for your help, I'd be here all night obsessing rather then laying a synth part. :)
Yeah, I recall a post a while ago where Keith DTS mentioned a possible conflict. Avid never did sort that one out, never mind. Glad I could help.
what is ProControl responsible for? and what it has to do with ethernet? do i need it since i would like to use axiom hypercontrol fully. another thing, what do you mean by "load the Pro Tools Mac Axiom Pro Patch"? do you mean a patch factory programmed in axiom for use with pro tools? if so i have 2 protools patches in there. I believe in #2 and #3, which one should i use? i hope you'll get an idea what i'm asking about. i know, so many questions thanks in advance
one more thing. my transport buttons in axiompro49 don't work as they supposed to, beside the flip button as mentioned before. |
Hello goldendawn, welcome to the DUC. Have you installed the latest M-Audio Axiom Pro Driver and firmware? Have you configured Axiom Pro in Pro Tools Peripherals (HyperControl I/O)?
thanks for response.
i downloaded and installed new firmware, which says it is 12may2011 on lcd on axiom, m-audio website shows this as the most current. as far as i know i didn't need any drivers since osx 10.6.8 has it already built in. "personalities" for axiom. I figured out that personalities are the same as drivers, yes?, so i didn't install any drivers. Audio Midi Setup shows axiom pro 49 as connected. Where it comes to Hyper Control i/o, im not sure if i didn;t screw something up there. just to double check, in Midi Controlers, change type to m-audio keyboard. then, receive from to HyperControl in. and send to, toHyper Control out. and channel should be in #8.
iMac OS X ver 10.6.8 2.5 GHz Intel Core i5, 4GB 1333MHz DDR3 Eleven Rack with Pro Tools 10 (10.3.6) AxiomPro49, Mackie MR8Mk2 Monitors, Glyph Portagig50 500GB FW800 Samson SM10 Line Mixer Monster Power PRO900 |
Excellent, launch Pro Tools and on Axiom Pro press Load>Group N>Number 2>SoftKey 4 (Load). This will load the Axiom Pro Patch for Pro Tools Mac. And no, you don't need to install any Personality as Pro Tools 8 and higher has the required Personalities installed.
AIR Hybrid Patches. Anyone? | herzinberg | Pro Tools 10 | 4 | 06-17-2012 08:35 PM |
Anywhere To Get Hybrid Patches? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-07-2010 08:34 PM |
Need hybrid patches | thenassaproject | Virtual Instruments | 6 | 05-16-2010 09:27 PM |
Moog Patches for Vacuum | RussUK | Virtual Instruments | 8 | 08-25-2009 03:51 PM |
Patches for Hybrid | Everything | Virtual Instruments | 1 | 11-30-2007 07:38 AM |
