Old 09-30-2016, 04:55 AM
waltersulivan waltersulivan is offline
Default Somebody HELP ! can't make axiom 49 keyboard work in protools 12
I have a problem , working 2 days to solve it but no success (( , I have ( 2nd gen axiom 49 ) it works fine with cubase
I have keyboard connected into USB 2.0 port . using 8.1 64bit windows
I tried "midi ox" software - selected axiom midi input and it reacts when i'm pushin the key it says :
0000AAC0 1 -- 90 3B 4A 1 B 3 Note On
0000AB31 1 -- 90 3B 00 1 B 3 Note Off
etc etc ...
whats wrong withthat keyboard in ptotools I dont know . by the way, in PT it plays sometimes sometimes not it plays when I open template for example , after that it suddenly stops playing ,
if I choose device, only in peripherals, then only transport will play
when I'm presing E9 E10 E11 E12 E13 E14 buttons on keyboard they react in protools , they work . (but not keys)
when I fill peripherals dialog with axiom input output, and also creating axiom into midi studio dialog input port : axiom 49 MIDI in Output: axiom 49 MIDI out
in that case protools says:
The original MIDI device associated with the MIDI controller "M-Audio Keyboard" could not be located
Please choose an existing MIDI device in the MIDI controler section of the peripherals dialog
my axiom screen sometimes shows strange numbers when I load protools, sometimes not ) I'm totally confused
downloaded latest drivers from m-audio
Axiom_Installer_1_1_2_Driver_5_10_0_6002
here is my system information
(unofortunately I can't instal sisoft sandra)
x99 deluxe motherboard
5820k 3.4ghz
32gb DDR 4 RAM
scarlet 2i2 audio interface
using windows 8.1 64bit pro
Old 09-30-2016, 09:16 AM
sw rec sw rec is offline
Default Re: Somebody HELP ! can't make axiom 49 keyboard work in protools 12
Gee, with ZERO system info, it's kind of hard to help much.
http://duc.avid.com/showthread.php?t=300050
Old 09-30-2016, 10:00 AM
I did some adjustments , can you please give it a look
Old 09-30-2016, 11:56 AM
etc etc ...
5820k 3.4ghz
32gb DDR 4 RAM
SOLVED !!!!!!!!!!
DAMN THAT DAMN SETTINGS
what a headache !
if someone experiencing same here is the solution
http://avid.force.com/pkb/articles/e...ia-USB-or-MIDI
Old 09-30-2016, 12:29 PM
YYR123's Avatar
YYR123 YYR123 is offline
Your connected to the computer how?
Did it ever work before?
What version of PT are you running?
Are you trying to run the keyboard with hypercontrol? B/c I believe that's been dead for a few years!
Daniel
Old 10-10-2019, 11:25 AM
Inglesworth Inglesworth is offline
I am having a similar issue, but this linked article doesn't exist anymore. Anyone happen to have the solution written out and/or a new link to the article above?
Old 10-10-2019, 06:43 PM
unkJE's Avatar
unkJE unkJE is offline
Pro-Tools-11-not-receiving-MIDI-signals-from-my-keyboard-connected-via-USB-or-MIDI
Last Updated: January 10, 2019
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife!
How do I make my Keyboard work in PT 11 Edmoses Pro Tools 11 0 09-05-2014 01:48 AM
Axiom Pro - Hypercontrol keyboard w/Protools 8 LE shawnusa MIDI 20 06-06-2010 01:25 AM
Axiom keyboard sends CC messages to PT LE 8 – how do I make it stop? DanielWiklander 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-03-2009 12:29 PM
Axiom pro 61 and protools 8 to work together with Superior Drummer 2.0 Rado Pro Tools M-Powered (Win) 2 10-26-2009 10:45 AM
can make the keyboard follow protools, but... GothicV 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-05-2004 01:21 PM
