Digi PRE - Start Up Troubles
Hello all! This is my first post here, so be gentle!
I'm having an issue with my Digi PRE. I turned it on and the readout reads 8.8.8. just like always, but it freezes there. Never moves on. No sound in or out other than a thump on startup. Can't select or mute channels, none of the buttons get a response. I've tried restarting and then I unplugged it, waited 30 seconds, plugged it back in with the same result. I've got a band coming over in two hours and I'm getting freaked out. Has anybody here encountered this problem? Thanks in advance for the help! Greg |
Re: Digi PRE - Start Up Troubles
this seems to be happening more and more. are you running pt version 8.x?
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4 32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE |
I'm not actually using ProTools yet. I'm using logic with the PRE in stand-alone mode. Its not hooked up with MIDI to anything...
I'm in the process of building an HD system and bought the PRE before anything else because it was a step up from my old pre's. When it worked, anyway... Any ideas? I just saw another thread saying it might be the power supply. Doesn't seem quite right to me, but what do I know. I just like to make music! |
Just in case anybody has this problem in the future, it was a corrupted boot loader chip. It has to be shipped off to digi in California to be repaired. Cost is 375 bones which includes return shipping.
So much for that 421!!! Oh well, I suppose these things happen... |
I can fix this for you with no problem
I've fix this error before and it may have been what they said but from my experience ...It's always been something else There is 3 other reasons for the same error than the boot loader ( CPU/ firmware ) IC being bad My repairs typically are near 50% of the OEM Contact me at the info below if needed Thanks M
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
The answer would be no, as long as your coming from a midi port from another device, even if you made the cable completly wrong it can't hurt the Midi Input or output of the PRE Now a noisy or bad signal can crash it, or bug it out, but in no way way can it permanently hurt it In the worst possible case it would damage the midi port itself But again in no way would it affect or damage the internal components beyond the Midi in or out ports Hope this helps
Given that MIDI is used to control the PRE, I would not be surprised to see some errant MIDI commands being able to lock it up...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
MOJO Troubles - Skipped Frames at Video Start | etwilliamson | macOS | 0 | 03-15-2012 03:55 PM |
start up troubles | jostitosti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-25-2008 02:37 PM |
Installation troubles with LE Digi 001. | pearlywhite | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-24-2006 08:14 PM |
MIDI troubles, PT 6.4...Digi? | Bhennies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-17-2004 09:28 PM |
Digi 7-Slot Expansion Bay Troubles | DOOM | Pro Tools TDM Systems (Mac) | 0 | 05-22-2004 11:07 AM |
