Pro Tools LE And PreSonus DigiMAX help!!!!!!!!!!!
I am new to pro tools and i recently got PTLE and a Presonus DigiMax. I have got it to work before. But i think i messed something up when i was messing around with the sample rate settings. When i open a session it will only let me use 2 tracks of the DIgimax. I know if you want to run 88.2k or 96k you can only use 2 tracks, but 44.1k is slected on the digimax. So im unsure of what it could be. If anyone can help that would be great. I need all 8 pres working not just 2. Thanks!!
Re: Pro Tools LE And PreSonus DigiMAX help!!!!!!!!!!!
make sure when you made a new protools session that the sample rate is 44.1 as well.
Also make sure that the 2x light on the digimax isn't lit up.
G5 1.8DP 4 gig ram, 002 Waves Platinum, UAD-1 Studio Pak, Reason 2.5, BFD Presonus Digimax 96K, UA 6176, Mackie Onyx 1640 |
Check your preferences, under hardware settings select ADAT external clock.
Also, check your in/out settings to make sure they are set up to accept all of the Digimax (ADAT) inputs and outputs. |
Pro Tools 9 not cooperating with Presonus Firestudio and Digimax Fs | MT21 | macOS | 3 | 02-17-2012 10:56 AM |
Connecting 003 Rack to Presonus Digimax LT via Pro Tools LE 8.0.5. Help | DiscoBilly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-09-2011 08:59 PM |
Presonus DigiMax FS | Obsidian Dragon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-16-2006 10:44 PM |
Pro Tools LE And PreSonus DigiMAX help!!!!!!!!!!! | DrummerGuy09 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-10-2005 08:11 PM |
Just got a Presonus Digimax LT!!! | PRS4LIFE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-24-2003 08:41 PM |
