Old 06-30-2020, 11:28 AM
RuffinMedia RuffinMedia is offline
Default Pro Tools and Reason Lite 10
I used to use Pro Tools with Reason years ago with Rewire. I acheived this by creating an instrument track in protools and I would select the rewire plugin, which would link Reason. I do not have Rewire as a plugin option in protools. How can I achieve this? Is there a way to manually install rewire? Ive searched on the internet for a rewire download but all the links are dead. Is there a new way to link/sync pro tools with reason or does rewire still work? If so, how can i resolve it?
Mac Mini 2.5 GHz Dual-Core Intel Core i5 - 16gb Mem - MacOS Catalina 10.15.5 - Pro Tools 2020.3.0
Old 08-14-2020, 09:21 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Pro Tools and Reason Lite 10
New Reason rack works great.
No rewire required.
Reason is Now in 3 versions for purchase or upgrades
Drop by the Reason site.
Old 08-16-2020, 04:27 AM
ChuckS ChuckS is offline
Reason 10 should show up as an instrument. Pick that and PT will load rewire with Reason if everything is installed correctly. The new version Reason 11 loads as a plugin so rewire is no longer needed/supported.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Reason lite and Pro Tools 2020? itsjustmeee123 AAX Plug-ins 2 06-30-2020 02:59 PM
Ditch Reason Adapted / BFD Lite? EarBud Virtual Instruments 5 07-20-2010 06:00 PM
Live Lite 6.0 & Reason adapted w/PTLE 7.4 Vista casperfun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-02-2007 06:06 AM
PT and REASON / LIVE LITE vjk Pro Tools M-Powered (Win) 4 06-29-2007 06:40 PM
PT and REASON ADAPTED / LIVE LITE vjk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-25-2007 08:36 PM
