PT11 audio dropouts when recording BFD3 and other virtual instruments
Hi guys
I would love some advice... I am a long-term (since 1995) Logic Pro user, and have recently moved over to Pro Tools 11, based on the great performance and track count the new AAE can offer, at low latencies. Here's an overview of my setup: iMac 3.5Ghz i7 with 24GB RAM (late 2013) OSX Mavericks RME UFX with latest drivers Pro Tools 11 native When I set up PT, we had a jam to test multi-track recording at low latencies. We recorded several synths, a guitar, and also tracked BFD3. All tracks were recorded simultaneously with a buffer of 64 samples (more on my audio settings in a moment). Everything worked perfectly - BFD3 ran without a glitch (although glitches were noticed when we went down to 32 samples), and the audio tracks all recorded perfectly as well, some of them running through effects such as guitar rig in real time. The next day, I went back to the session and decided to re-record the BFD3 drum parts. I started recording, and noticed that BFD3's audio was breaking up at reasonably regular intervals. This had not happened in the previous session when we recorded all the tracks at once. My "playback engine" settings in PT11 are as follows: Playback engine: Fireface UFX H/W buffer size: 64 samples Host engine: [TICKED] ignore Errors during playback/recording [NOT TICKED] Minimise Additional I/O latency [TICKED] Dynamic plug-in processing Video engine: [NOT TICKED] Enable The only other change to the session was an additional track was added, running newly installed OMNISPHERE (current version). This track was not enabled for recording, and did not have any recorded data on it. My concerns are that I had expected that at 64 samples, I would get artifact-free audio from plug-in instruments as well as audio tracks. The first simultaneously-recorded multitrack session seemed to point towards great performance in this way. My previous DAW, Logic Pro (most recently X), is performing well at 64 or even 32 samples with heavy projects. Recent tests on this forum have suggested that PT11 can deliver a higher track count with the same plug-ins, when compared to Logic Pro. I would love some advice on what I should try next. Are my audio engine settings (above) the best for this situation? Are there other settings I should change to improve low-latency realtime recording of AAX instruments? Any advice would be gratefully received! Thanks in advance, Mike
Mike Pooley (Sydney, Australia) iMac i7 3.5GHz + RME UFX + Event Opal + Nord Stage 2 + Korg Kronos 73 + Kurzweil PC3-61 + Dave Smith Prophet 08 + Roland Juno 106 + Roland V-Drums TD12 + Yamaha U1 piano www.thepeopledownstairs.com |
Re: PT11 audio dropouts when recording BFD3 and other virtual instruments
Untick it, then play back. Do you get error messages?
Disable Omnisphere (right-click and choose "disable"). Play back. Same behavior? If it runs fine, enable omnisphere. Play back. Does Pro Tools stop the transport and display an error message "DAE -6301" or something like that, claiming you're running out of CPU power? Your system should perform flawlessly, even with multiple hungry VI's and a low buffer size. You've updated Pro Tools to 11.1, right? |
I will try some of these additional troubleshooting steps - I had definitely expected PT to run perfectly on this new system, especially when the test project was actually very small and should not have put any significant demand on the CPU. I haven't updated to 11.1 yet (I am away at the moment, returning home in two days), but will update as soon as I get back before trying any further troubleshooting. Thanks again, Mike
Since your previously-stable system started having problems, you should try to isolate the problem before introducing another variable. I would suggest that you test with your current installation of Pro Tools. Load an Omnisphere insert and follow these steps:
This will help you isolate the problem. |
Virtual Instruments for PT11 | visionstudios | Pro Tools 11 | 2 | 12-24-2013 06:44 AM |
Mbox2 PT11 and virtual instruments | FabriceMg | Windows | 3 | 10-09-2013 10:31 AM |
Missing Virtual Instruments: PT11 [solved] | Paul Sombric | Pro Tools 11 | 27 | 07-23-2013 01:30 AM |
Avid Virtual Instruments for PT11 | danika | Pro Tools 11 | 2 | 07-02-2013 08:55 PM |
Recording audio vs virtual instruments | uptowners2010 | Pro Tools 9 | 6 | 08-24-2011 05:28 PM |
