Old 04-01-2009, 04:55 AM
masta1 masta1 is offline
Banned
Question Recording quality suddenly horrible? PT8 - files in here.
I got a really annoying problem, my recording quality suddenly has gone down hill. Now all other sessions are fine the mbox is working the mics still recording but anything new is sounding far inferior to previous recordings. (Below is a recent session i opened and recorded on the same track before the verse kicked in to show the horrid new and the good old.)
Example audio acca - 1 (unmixed)
Audio example mixed
When i record with reverb and rcomp rvox on the vocal so i can hear it back as i'm recording it sounds fine however when the verse is done it sounds like eg. 96kbps does compared to 192 - i can up an example if that might help understand what is wrong.
I don't think it's my mic or my mbox and i haven't changed anything around either.....Any ideas?
Old 04-01-2009, 03:44 PM
TOM@METRO's Avatar
Default Re: Recording quality suddenly horrible? PT8 - files in here.
Are you perhaps pushing the levels a little hard in the plugins?
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 04-01-2009, 07:33 PM
TOM@METRO's Avatar
And?
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 04-02-2009, 12:06 AM
Banned
No the levels are all fine even when the plugins aren't on there's a huge difference between how it used to sound and now..
Old 04-02-2009, 09:05 AM
The Night Train The Night Train is offline
I know you said you haven't changed anything, but I have to ask..
Any changes in mic placement/location? Is this recording being done in an iso booth?
The new (first half) of the recording sounds like there is a reflection off of glass, right near/behind the mic. For example, your microphone is in an isolation booth right near or backed up to the glass window.
It may be grabbing at straws, but that's what it sounds like to me.
If you don't have it backed up, do you really have it?
[ Mac Pro 4x2.66 | 3x23" | 5GB | 4x500GB int. - 4x500GB ext. | 10.5.5 | PT8 003R | Command|8 | BM-5A's ]
[ Macbook Pro 2.16 | 17" | 2GB | 1x120GB int. - 2x250GB ext. | 10.5.5/XPproSP2 | PT8 Mbox2Micro ]
Old 04-03-2009, 06:24 AM
Banned
Cheers for replying, but no haven't made any changes to the recording surroundings mic position, it just sounds worse quality?
Old 04-03-2009, 07:05 AM
Hmmm...
There is no "make my recording sound bad" feature that you would have turned on.. so I'd calculate that one of the pieces of equipment you have has become faulty.
To troubleshoot your problem:
- If your using Mic input #1, then switch over to Mic input #2.. any better?
- If you have a spare mic cable, switch it out and check the results
- If you have another microphone, switch it out and check the results
If you don't have a spare mic or mic cable, can you borrow from a friend or take yours into a local music store / pro audio shop.. Ask them if you can plug it in to their gear, as you may need to make a purchase if your cable or mic is bad.
If everything above checks out, then you can test your interface (Mbox) by looping some audio out of the unit, the back into itself.. Have a couple of tracks setup, 1 playing and the other recording.. Connect a cable from the output to the input. If it drastically changes the sound of the audio, your audio interface could be the issue.
Old 04-03-2009, 10:11 AM
spkguitar's Avatar
You might also want to update those plugins...
Recording Vinyl - horrible digi-noise, distortion, pops swamp gravy Pro Tools M-Powered (Mac) 2 07-20-2009 04:52 PM
Horrible noise on bass amp when recording! idledude Pro Tools M-Powered (Mac) 6 01-07-2009 12:57 PM
Mixdown quality is horrible Mad Genius Audio Pro Tools M-Powered (Win) 10 06-29-2006 06:58 AM
Acid Files make horrible 'Clicks' after Import orangepopsongs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-29-2006 02:31 PM
Horrible, Horrible, Skreeching Noise On Drum Track in Sampletank William.E.Lemuel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-09-2002 06:54 AM
