Old 12-20-2014, 06:26 AM
tonykitowicz tonykitowicz is offline
Default Does this mean any app or just iTunes won't work with HD Native on Yosemite for 11.3?
In the readme file for 11.3 there is a note that iTunes will not work with HD Native using CoreAudio Manager until there is a driver update. Does this mean that if I try to use Logic Pro or some other app with CoreAudio Manager/HD Native on Yosemite that it won't work either, or does this readme specifically (and only) warn about iTunes?
Thanks!
Tony
"On Mac OS X 10.10 (Yosemite) only, iTunes does not work with HDX or HD|Native hardware using the AvidCoreAudio manager. (PTSW-194693)"
The Avid CoreAudio Manager is currently not compatible with Mac OS X 10.10 (Yosemite) and a driver update will be required.
Old 12-20-2014, 06:51 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Does this mean any app or just iTunes won't work with HD Native on Yosemite for 1
It specifically mentions iTunes, so no, I don't believe it is a common CoreAudio issue...
Janne
Old 12-20-2014, 06:53 AM
Thank you, that's what I was thinking but wasn't 100% sure.
Old 12-20-2014, 06:58 AM
JFreak's Avatar
I'm not 100% sure either, because I have my hands full with unanswered messages. Can't test right now. But my educated guess would be the issue is with iTunes specifically.
Janne
Old 12-25-2014, 06:59 PM
21 Junipers 21 Junipers is offline
Anybody test other apps w/coreaudio?
Thanks!
Old 12-25-2014, 09:50 PM
Seafoam_Green's Avatar
Seafoam_Green Seafoam_Green is offline
Thanks!
I find that sometimes I play You tube clips and the sound comes from my mac onboard speaker instead of from my MBox 3 pro / monitors
This NEVER happened before if My MBox3 pro was switched on .
Note' previously - I didnt even have to have the Mbox turned on during the Mac startup . Even if the mbox 3 pro was turned off (meaning no monitor playback) the instant I turned on the MBox 3 - playback resumed to my monitor speakers (away from the onboard mac speaker)
Now ..., whenever this happens , I have to restart my Mac to make the monitors work again
For pro Tools use, I will always boot up with Mbox pro turn on beforehand ..., but when not using protools I always like to be using my monitor speakers / via the MBox 3 Pro interface for everyday use ..., and if you heard the crappy inbuilt onboard speaker in the new mac Pro , you would understand why .
Old 01-22-2015, 11:10 AM
My initial instinct was correct, the HD drivers with core audio do not work on Yosemite. Protools runs with HD Native, but if you try to use anything else with core audio (iTunes, Native Instruments, Logic Pro) don't work and the apps need to be forced quit when starting.
If I remove the core audio plugin, per the workaround from Native Instruments then those apps startup and function, but I have no access to my HD Native setup.
Old 03-20-2015, 08:17 PM
Cubase 8 works....
Old 04-28-2015, 03:45 PM
Oroz Oroz is offline
Just finding out about this problem. Another thing to add to the pro tools absurd way of working.
I sure will be changing DAW.
Such a shame.
Old 05-08-2015, 05:49 AM
kurt's Avatar
kurt kurt is offline
Thanks!
Tony
You have described two very different situations. CoreAudio works fine with Logic & Cubase. On Mac, when listening to YouTube - iTunes thru Pro Tools, it has always been simplest to connect Computer - Audio Interface, with SP/dif:)
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5
PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear.
http://www.mmvstudios.com
Yosemite !!!! Protools don't want to work help !! Gibbsone16 macOS 29 12-09-2014 03:16 AM
Possible to get Digi003 to work with iTunes? toddamo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-20-2008 09:23 AM
New Itunes 7.0 (don't work) ! stratoj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-17-2006 11:22 AM
OT: iTunes 4.0.1 won't work terrydrums 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 06-15-2003 11:25 PM
Does iTunes work with PT6? Imagine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-02-2003 02:00 AM
