Low Input Levels on my 888/24
Why are the input levels so low on my 888/24? I've tried recalibrating and using the suggested -18db head room and the input levels are still to low. I connected my synth directly into the 888/24 via analogue and the synth output was at maximum. The input level was not even touching the yellow on the 888/24 and/or in the aux strip that I assigned in protools. The same thing happened when my friend brought over his summit. I thought maybe a preamp would be the solution to my proglem, synth -> summit -> 888/24. When we cranked the summit, the sound got distorted but the input level on the 888/24 and aux strip in PT didn't budge much. Any ideas?? [img]images/icons/confused.gif[/img]
Re: Low Input Levels on my 888/24
Have you checked all of your cabling? Maybe you have some sort of unbalanced to balanced cabling problem that's cutting and distorting your signal. If you take 2 good XLR cables and connect one from the summit to the 888 and the other from a microphone to the summit, can you get good level from the mic? Is it all of the inputs that are low or just the first one?
Your synth almost certainly is a -10dBv output. Run into an 888/24 which is +4Bu, you're gonna see some low levels. I suggest a Line level shifter such as Ebtech's Line level shifter or a Matchbox...then I think you'll see happly levels. -Todd A. |
Shawn,
Yes, I made sure I used high quality balanced cables. I'm having this problem across all input channels. I've even tried switching the 888's channels 7-8 internally to -10 via the jumpers and after recalibrating, the input signal seemed to be a bit louder but not by much. I even tried turning the input signal pan pots on the 888 all the way up and I still got the same result, maxium input barely touched yellow. I'm curious, is this how the 888 is suppose to be when you connect a synth directly into its input? Have you ever tried this before and got the same results I have? |
how low is it ??? -18 dbfs may seem low , maybe you gonna recalibrate the interface if you just using synths . the -x dbfs calibration idea is to give you an ammount of headroom . if you would connect your synth to an " analog mixer " and you would level it to 0dbvu your interface would show -18dbfs ( which isnt even in the yellow zone of the 888s meters ). the output circuit levels the -18dbfs digital signal back to 0dbvu . ( if used with an analog mixer ) . i guess wrong " balanced " soldering may cause another lack of 6db . i cant remember eitehr the in or the outputs have to be " bridged " to have a balanced signal flow . ( its in the manual ) .
heres how i calibrated my interfaces : sinus tone 1khz to a analog device with vu meters . the 1khz tone needs to be +6db that the vu meter shows 0dbvu . i calibrated the inputs to -10dbfs with that signal . so if a signal recorded with 0dbvu , the interface shows -10dbfs and the output to my analog mixer shows 0dbvu . thats how it works for me. the bad thing bout that idea is if you wanna do a 2trackmixdown . f.ex working with a analog console : your mix shows maybe +4 db on a peakmeter . so your still ~12 db away from a full scale signal . either you lose now resolution or you have to raise the master fader on the board ( which might distort ) . so i make sure if have 2 inputs calibrated to -4dbfs . same thing with sample cds . those signals are already mastered ( whyever ??? ) . 0dbfs and you will have +18 dbvu on your console , you gotta move the PT faders without having WW3 on your monitors . andandand , good luck p.s i dont think the summit should distort by raising the level 10dbs . let us know what your " levels " are . but i guess i know what you mean , digital can be a little confusing . |
What you need is to open the 888 and change the jumpers to get a -10dbV reference level. See 888 manual for this.
If you try to drive a 888 near 0db full scale with the reference level set at +4db, you are asking your source to deliver levels in excess of +20 db ! Most of the time this will result in distorted signals. |
C/24 input levels | 67es335 | ICON & C|24 | 0 | 09-04-2011 11:26 PM |
Input levels on HD-1 96K | BHeller | Pro Tools TDM Systems (Mac) | 2 | 06-05-2002 12:39 AM |
low input levels 2 | sadhits | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-26-2001 08:23 AM |
888/24 input levels | 3james | Pro Tools TDM Systems (Mac) | 5 | 07-25-2000 01:31 AM |
Input Levels | bugsy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-18-2000 05:31 PM |
