Old 10-08-1999, 05:13 PM
pyro pyro is offline
Default need 2nd opinion
when burning a cd,how hot sould you burn it.and what is the best way to meter the level that will be going to cd. I'm pretty new to this protools thing and one of the main comments I get from some clients is this HEY MAN, HOW COME WHEN I PUT YOUR CD IN ITS NOT AS LOUD AS OFF THE RACK CD'S???????? WHEN I TRY TO BURN THE CD HOTTER THEN IT DISTORTS.WHAT AM I DOING WROING AND HOW CAN I GET THE BEST BURN POSSIBILE.AGAIN HOW DO I METER FOR BEST RESULTS
Old 10-08-1999, 07:18 PM
Jim Roberts Jim Roberts is offline
Default Re: need 2nd opinion
Pyro,
If you're going for LOUD, I would use Waves L1. Set the top to -3 and go for it.
Obviously, this doesn't work for everything AND it must be used tastefully, but it will make things loud.
Jim
Jim Roberts
www.musicandvideo.tv
Old 10-08-1999, 10:30 PM
blairl blairl is offline
Many of the top mastering engineers are campaigning to get the levels LOWER on commercially released CD's. The dynamics are GONE on most of todays CD's and they want them back. However, they aren't having a lot of success because the people that pay the bills want their CD's louder than the next guys.
Old 10-11-1999, 10:46 AM
Kris Kris is offline
The L1 does the metering and the gain increase, therefore, don't do any gain change when you burn.
My studio: http://www.logcabinmusic.com
Old 10-11-1999, 11:18 AM
thanks guys for the replys. So my only concern when using L 1 is that my main master fader does not peek?? is this correct.I run My mixes back through a console with everything set at unity because I think PT internal mixer buss is not so good. then I come out of the console back to PT to two tracks. and then go to cd. If my master fader says I<m not peeking somtimes my console is at +7db How can I moniter at the console for best results for the hottest cd with/out peeking. I know this sounds like alot of trouble. would be open to better ideas..with out spending any more money. do I want to not let the console get over 0db or what..help....
Old 10-11-1999, 11:19 AM
Need your opinion DocMoD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-05-2007 10:43 AM
Need an opinion about going from 6.4 to 7.1 Telepc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-26-2006 08:51 PM
your opinion on PRE vs. 96 Nils Groth Pro Tools TDM Systems (Mac) 3 06-29-2006 09:00 PM
Your opinion on this PC: swix76 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-10-2003 10:50 PM
your opinion harpua6 Tips & Tricks 1 09-03-2002 01:08 AM
