Old 10-08-1999, 04:56 PM
pyro pyro is offline
Default need opinion
can any one comment on which eq sounds better between focusrite d2 plug in and renaissance eq plug in. Also, does d3 sound alot better then the stock compressor that comes with protools 24
Old 10-10-1999, 01:53 AM
Fokke van Saane Fokke van Saane is offline
Default Re: need opinion
Focusride EQ is very transparent, and Filterbank rocks. I use Focusride for the high and FB for the low. I'm not familiar with renaissance eq.
Focusride compressor is very good, like the eq very transparant. Sometimes i use focusride, sometimes Drawmer. FB is also very nice, but since i own two good ones i dont need another good one.
Digirack is about to leave my plugins folder. I only use dither and delay.
You can download demo's of Filterbank and Compressorbank at http://www.mcdsp.com
Please try them out. Also much cheaper than focusrdide, although focusride supports the dsp manager meaning dsp plugin sharing.
Use your ears.
Fokke.
Old 10-10-1999, 08:33 AM
fokke,thanks for the reply,I,ve heard that fb is the plug in to have. thank for the info on were to down load demo. hope I can help you sometime. I charge less than the law allows on workman comp cases.kidding....thanks
Old 10-10-1999, 08:36 AM
Old 10-10-1999, 08:37 AM
Old 10-10-1999, 10:57 AM
one 'thank you' is more than enough.
Need your opinion DocMoD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-05-2007 10:43 AM
Need an opinion about going from 6.4 to 7.1 Telepc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-26-2006 08:51 PM
your opinion on PRE vs. 96 Nils Groth Pro Tools TDM Systems (Mac) 3 06-29-2006 09:00 PM
Your opinion on this PC: swix76 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-10-2003 10:50 PM
your opinion harpua6 Tips & Tricks 1 09-03-2002 01:08 AM
