Pro Tools Digital Connections
Hello all, I am preparing to record a project for my praise team. We have a Behringer X32 Compact at the church that can be used as an interface. With the multiple inputs, how do I get them into my computer? Do I need something between the mixer and the computer? I will be recording into a twenty15 mac book pro.
Re: Pro Tools Digital Connections
You just hook up a USB cable to the back of the unit. Protools will see the X32 as a 32 channel audio interface.
You may need to download a driver from Behringer to make it work. Consult your manual. Keep in mind that it will only do 32 channels over USB, so if you have more inputs than that plugged in on the mixer, you will have to sacrifice something (there may be workarounds to this). Also, you have the choice of recording to the Macbook internal drive, but you may also want to record instead to an external drive. I would maybe test this ahead of time, before the actual event. As for the USB cable, it needs to be USB A on one end and USB B on the other. Exactly the same type of cable used to connect most printers to computers. You could even borrow the one from your printer. |
IIRC, if he has Pro Tools Vanilla, then only (the first) 32 record channels will be available - 32 record track limit in PTV.
Cheers,
Thank you very much for your responses.
HD i/0 Digital Connections. | YYR123 | Pro Tools HDX & HD Native Systems (Mac) | 3 | 10-06-2015 01:08 PM |
Need suggestions on connections digital to digital | wasabi | Pro Tools TDM Systems (Mac) | 2 | 05-22-2006 10:02 AM |
Digital Gear Connections III | sean shannon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-03-2002 02:02 PM |
Digital connections??? | sean shannon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-17-2002 11:25 AM |
96K DIGITAL CONNECTIONS | Alécio Costa | Pro Tools TDM Systems (Mac) | 2 | 03-14-2002 10:55 AM |
