Old 03-24-2012, 10:52 PM
anth anth is offline
Default deleting unused files
I opened up a previously saved session (was originally a ptf file but now saved a ptx file). I went to the clips list and selected all unused tracks and deleted them (it gave me a warning about deleting the file permanently for each track which was annoying?). I then checked in the audio folder of the session and the tracks I had just deleted were still there?
Also, say if I started recording new tracks in the same session and then decided not to keep them. Can I just close the session file without saving to remove the newly created audio files from the hdd or do I have to delete unused tracks again before exiting.
Old 03-25-2012, 05:05 PM
Exclamation Re: deleting unused files
You can hyold the option key when clicking on the button in this window to have that choice applied to the same question for the remainder of your operation.
If you selected and deleted the track, this would be expected. If you selected and deleted (not removed) the clips, then this is not right. Which did you select - the tracks or the clips?
No.
You have to delete the tracks you do not want to keep, then select unused clips and delete the unused clips.
Deleting unused files? Danny Winn Tips & Tricks 19 04-23-2020 08:05 AM
deleting unused fade files der daniel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-17-2009 12:21 PM
Deleting unused audio files Beyond The Pale 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-15-2006 09:49 AM
Deleting unused, lost files, Bug or Me? flymax Pro Tools TDM Systems (Mac) 4 03-08-2006 10:29 AM
Deleting unused files question jwd65 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-26-2004 06:05 PM
