How do you make legit violin portamento using Structure?
In Structure, the violin (all orchestra strings) do not have portamento. Using pitch shift sounds fake. So I have experimented with ways to achieve a real sounding portamento. Wondering if others have too? What is your trick?
What I do is put in a chromatic series of notes. But then pencil in a pitch shift of a half step (set Structure pitch bend to +/-1) to connect the notes so there is an effective continuous slide. It sound pretty good actually. And you can cut/paste the chunk of data to every portamento note. If you try and slide the pitch shift for more than a few semitones it sounds fake. Any other thoughts?
DC-Choppah's Project Studio: ASUS PRIME Z390-A / Intel i7 rackmount PC Windows 10 home 64 bit Pro-Tools 11.3.1 AIR Instrument Expansion Pack v2 WAVES Platinum plugin bundle Tascam US-16x08 Interface 100% Analog real time monitoring 16x4 Yamaha 16 channel MG16XU Analog Monitor Mixer Yamaha MX-88 / Novation XiO keyboards Mackie 4-channel headphone amp Adam A8X monitors Blue / Shure, etc. microphones Estonia 6' 8" Parlor Grand Piano Yamaha Studio Drum kit https://www.dc-choppah.com/ |
Re: How do you make legit violin portamento using Structure?
[Mono Mode] Glide in the main edit [Part tab] window is portamento.
Air V2
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
Mono mode makes sense. This sounds pretty good as long as I make the portamento times realistic. The glide time control lets you do some unrealistic things if you let it. Not sure yet what the legato switch does and how that is different than the glide setting to legation in the drop down menu (on/off/legato). So you could set the legato switch to 'on' while glide is set to either on OR legato. Trying to use my ears to figure out what is being controlled. Buit this is still not real violin portamenti where they use a 'new' finger or 'old' figure to hit the notes. Real violin is more of a glide then jump, or jump then glide. The glide effect is generating a pure glide between notes - not what string players do. But I can pencil in the jump note (new finger) and then automate the turning on of the glide to the next note. This could work! Thanks Detroit. DC
I have a different solution to the problem - I write the string parts in Sibelius and notate a glissando with a slur and the portamento line under the slur, and usually whichever Virtual Instrument I assign to that MIDI file when in Pro Tools reads the portamento.
It works with trombone glisses too. No slurs but lines: |
There is no way to enter the gliss (line) using the PT score editor directly. Like was said, you have to export the score to the real Sibelius. Too bad.
I am going to stick with the glide function in Structure and just automate it on/off when I want a portamento played.
I always though Avid should make Pro tools have a score editor that was a "Sibelius Lite" rather than the 2nd-rate score editor they supply. |
Right. I don't see any real use for the PT score editor. It is a limited function MIDI editor and entry level basic music notation gadget. There is better freeware available for just making charts. I guess that is why I don't end up in there very often.
I am learning to automate the Structure glide on/off with a MIDI button on my controller. Am learning to play the Structure strings where I turn on glide when I want to do a portamento. You can play the new fingered note too, then hit the glide button as you go up from there. This is making it much faster to get the parts in properly. I'd rather stay out of the editor if I can.
It's all the more silly because Avid owns the best or 2nd best notation software, Sibelius.
Digidesign Structure Sounds 67 - Solo Violin Pt 1 | RussUK | Virtual Instruments | 4 | 12-12-2016 02:48 AM |
Make my own Structure patches | Jay_dammit | Virtual Instruments | 2 | 07-04-2012 10:56 AM |
Legato and Portamento violin and cello sections recommendations? | harry3232010 | Virtual Instruments | 2 | 05-11-2011 07:10 PM |
Structure Free 1.0.2 update will make you unhappy. | j77swift58 | Virtual Instruments | 0 | 04-18-2011 09:17 AM |
Can I make a Structure patch with Structure Free? | weezerboy | Virtual Instruments | 11 | 03-28-2011 12:04 PM |
