Old 01-05-2021, 01:19 PM
Andrew2021 Andrew2021 is offline
Default Stuck at the First Hurdle - retrieving 'saved' project
Hi there:
I am brand new to using Pro Tools First and have become stuck right at the start...
-I have begun with 'Create' a project and successfully recorded a couple of test tracks.
-I assume, I have done this correctly in that I am able to visualise the sound input and am able to listen back to these tracks
-I then have named the project and clicked 'Save' under File
However, upon subsequently reopening of Pro Tools, I am met with the welcoming window which lists the names of projects available to 'Open'. When I click on 'Open' nothing happens... I have tried this several times and have never been able to access recordings made on a previous session...
It is curious that while my project titles are saved and displayed, and I am given the opportunity to 'Open' them, but I cannot actually open or retrieve any recordings...
It seems like the most rudimentary step that I am missing - perhaps my recordings are never actually being saved or perhaps they are 'there', somewhere, but I cannot retrieve?
Any advice for a confused newbie!?
Old 01-06-2021, 11:22 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Stuck at the First Hurdle - retrieving 'saved' project
I guess first let's see if your problems are related to projects in general or if they are not backing up to the cloud properly.
I would try to create a new project, this time make sure the backup to cloud checkbox is NOT checked.
Add a couple of test tracks, record some audio, MIDI or whatever you want to test out. Then, like you did, File -> Save. After saving, choose File -> Close Project, which will close the project, but not PT.
You should now be back at the start window and should see your new local project in the list. Try opening it and see if you get any further. If not, then something could be wrong with your installation and I would uninstall and reinstall PTF.
If you were able to open it successfully, then it would seem that PTF is working, but the actual cloud back is not.
For another test, create a new project and this time make sure the Backup to Cloud checkbox IS checked. Just like before, add some tracks and record some audio. Now go to File -> Save. After saving, go to Window -> Task Manager, which will display the task manager window. Now go to File -> Close project. After the project closes, you should see some activity in the task manager window about syncing with the cloud. Wait until all tasks have completed, then close PTF. Now restart PTF and see if you can open the project you just created.
Hope this helps.
Will
System Details
Old 01-17-2021, 11:46 AM
Thanks Will K:
I haven't managed the time just yet but thank you for the suggestions. I will follow your advice and get back with an update.
All the best
Andrew
Reloading a project I just saved 10 mins back..can't find files? TNM Pro Tools 2019 7 02-23-2020 03:59 PM
Pro tools first crashes when trying to open saved project Fat32 Pro Tools | Intro Discussion 0 02-02-2018 09:42 PM
Are plugin parameters saved in project? David.Straley Pro Tools 11 14 11-04-2016 02:10 PM
Can a saved project in PT8 be opened in 7.4x? Daviskenn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-22-2008 07:31 PM
sends not working when opening a saved project. ashdeini 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-11-2006 06:51 PM
