Old 10-03-2015, 02:59 AM
Stig Eliassen's Avatar
Default Reason 8/ PT 12.2/ AAE error -20038
Latest build of Reason installed, and I can't get Rewire to work. I get AAE error -20038 every time I try to instantiate Reason as a plugin inside PT.
Thoughts?
Old 10-03-2015, 03:50 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Reason 8/ PT 12.2/ AAE error -20038
Did you try to Launch Reason 1st in standalone?
removing The Avid Core Audio in the Audio>Plug-ins>Hal folder?
Old 10-04-2015, 12:03 AM
I did run Reason standalone first, but got the error when trying to rewire it.
Trashing the plugin in the Hal folder worked. Thanks a lot.
Old 11-07-2015, 09:05 PM
Sreitman Sreitman is offline
I am actually still having this error even after removing the core audio plug from the HAL folder. Starting in reason first also does not work. Any other suggestions by any chance?
Old 05-26-2016, 08:09 AM
Iker Piedrafita Iker Piedrafita is offline
I had this problem too, it solved mysteriously inserting reason in an instrument track, not in an aux track. When I try in an aux track I keep getting the AAE error -20038 message.
Old 06-06-2016, 06:54 PM
nekobass nekobass is offline
Hi. I'm having the same problem but I don't have that "Avid Core Audio" in the HAL folder. Am I missing something?
Pro Tools 12.5 LE
Reason Essentials 8
Mbox Mini 3
Mac Mini Core i5 - 8 Gb Ram
Old 07-27-2016, 05:17 PM
PhilG PhilG is offline
This is still a problem I think. I encountered this after changing settings on my Audio Interface. I uncheck Ignore errors during playback.... It deactivated Rewire Plug in and also crashed reason. Its the least of my worries though because Reason rewired is giving me major performance problems.
For those who are wondering I was reassured by a lovely support member that I can be issued a refund from the 1 month sub if tech issues are a problem with my system.
It seems that the mbox 2 is functioning in 12 after all.
Old 11-28-2016, 09:45 AM
ideophonic ideophonic is offline
I got this message from Propellerhead which solved it. Hope it helps anyone.
"Hi Carlos
Thanks for your message
In Pro Tools 12 ReWire devices are scanned only the first time you launch Pro Tools.
To force Pro Tools to do this again, try manually delete the “InstalledAAXPlugIns” in <your user>/Library/Preferences/Avid/Pro Tools.
The user (~) Library folder is hidden by default. To find it, select "Go To Folder…" from the "Go" menu in Finder, and paste
~/Library/Preferences/Avid/Pro Tools
and click "Go""
Old 07-11-2018, 07:09 AM
vvrec vvrec is offline
"Hi Carlos
and click "Go""
It worked, thank you!
Old 12-12-2018, 11:41 PM
paddy_sound paddy_sound is offline
"Hi Carlos
and click "Go""
Thanks man, it worked for me. The only difference was that I was facing this issue while trying to rewire Ableton live.
Reason -> Pro Tools ... Quality Error asounds macOS 9 04-13-2011 02:00 PM
Reason Unknown Error, C++ Error, Plug-ins Inactive Paul_Cantor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-20-2009 09:54 AM
Pro Tools error when Using Reason with K/B ben111g Pro Tools M-Powered (Win) 5 05-04-2009 10:16 AM
error -600 and to force quit reason robsubway 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-11-2006 08:23 AM
Error -1501 PT LE 6.1 & Reason 2.5 Kendo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-06-2004 05:11 AM
