Old 10-11-2009, 01:19 AM
Breakdown Breakdown is offline
Default hELP REQUIRED
No doubt there is a simple and obvious solution but.....
I have been used Pro tools 8 and Mbox 2 for a while on a Windows XPbased system and storing sessions on a USB powered Hard drive. All worked fine, aside from the anticipated Interrupts stoppages.
Now changed to a dedicated HP DV6 lap top with Vista optimised according to advice here and a La Cie Fire Wire Hard drive. The issue is the sessions I have copied from the previous hard drive have no wav files visible and therefore play blank. All of the tracks are there, and the audio files are present if I check in the browser etc. but I can't get them into the session.
If I open the files on my old XP system all is fine.
What stupd thing am I miissing?
Old 10-12-2009, 08:15 AM
spkguitar's Avatar
Default Re: hELP REQUIRED
Well, two things;
  1. You are posting about the mbox 2/LE in the forum for MPowered and M-Audio interfaces. So many people get confused by the "M" in the name.
  2. Check the disk allocation of the session on the new system.(Setup-Disk Allocation)
Old 10-12-2009, 10:15 AM
Thanks for response. I have now posted in proper forum.
Disc Allocation confirm files are not in the right place..And then what... unless you could respond to my post in the proper place.
Thanks again.
Drummer Required White Fire Sky The Drum Room 0 10-20-2011 07:08 AM
Is iLok Required to run? Xollop Pro Tools 9 6 11-05-2010 09:16 AM
help required ! :O) bluebearddub Pro Tools M-Powered (Win) 4 05-08-2009 10:51 AM
Help required Oulton Raider 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-13-2007 07:52 AM
AKA help required.... james gayner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-29-2003 01:07 AM
