Old 08-18-2006, 12:04 PM
EricWillhelm EricWillhelm is offline
Default Time Shift: Why no pitch/time strap?!
Argh! unless I'm missing something, this new Time Shift plug-in once again seems to not have the ability to strap the pitch and time, so that the effect is the same as slowing or speeding up a tape. And even Waves, whose Parametric SoundShifter has this function, it doesn't do it without an unhealthy amount of phase weirdness in the resulting file. How hard can it be? I'd think that the pitch following the time would make for a nice clean conversion.
Anyone have an ideal way to do this? And again, all I'm looking to do is to achieve the same effect as slowing or speeding up a tape. NOT the process of it slowing or speeding up, just the end result. Like, say you are syncing a music track from a CD to an old video with the same audio but at a different speed, and you want to correct for it.
Just curious,
Eric
Old 08-23-2006, 01:48 PM
JimWest JimWest is offline
Default Re: Time Shift: Why no pitch/time strap?!
If I understand your post correctly, Time Shift does have the feature you're after. One of its modes/algorithms is called Varispeed. "Use to link time and pitch change for
tape-like pitch and speed change effects, and post-production workflows."
Jim West
Plug-in Program Manager
Digi
Old 08-24-2006, 01:22 AM
comprodman's Avatar
comprodman comprodman is offline
What you want is the plugin called "Speed" if you look on EBay it goes for about $25 with a $25 ILok fee.
Pro Tools Editor, Producer, Mixer and Masterer since 1998
Old 08-28-2006, 05:01 PM
Nope, that doesn't do it either. Tempo and pitch are completely independent of each other. I mean, you COULD do it, if you felt like working out the calculation for one setting once you've set the other. But SURELY there's a plug-in where pitch and speed are strapped, ISN'T THERE? There has to be.
Ugh.
Old 08-28-2006, 07:59 PM
accession accession is offline
Ugh.
Serato Pitch'nTime
http://www.serato.com/products/pnt/
Check the screenshots on the page: engage "Varispeed Mode" where "pitch is controlled by tempo settings".
I'd be surprised if it's not the only product to do it. Just a setting available to many similar plugs???
Old 08-28-2006, 08:58 PM
Kryst Kryst is offline
No offence really, but from a first year programming student's point of view, How hard could it be? Well, why don't you create the plugin software that can do what you want it to do, then show them how easy it is?
Kryst
Old 08-28-2006, 10:02 PM
Jim West
Digi
After d/l the PDF and plug-in, I just noted it does too, and came back to report it, and you'd beaten me too it.
To the original poster, what's wrong with the "varispeed" mode on the new FREE plug-in?
From the pdf:
Varispeed
Isn't that exactly what you want it to do???
Old 08-29-2006, 02:29 AM
Jon_Atkinson Jon_Atkinson is offline
Surely any sampler on the market (Reason, Kontakt etc) does exactly that?
In my experience if you need to varispeed a track, the best sounding results come from samplers rather than Speed or Pitch n Time (and believe me I've tried these!!).
Plugins like Speed seem to overcomplicate the process, and there are definitely wierd artifacts if you try and varispeed more than a couple of percent.
My favourite, sonically, is EXS24 BTW.
Mac Pro 2019 3.5GHz 8 Core 48GB RAM
OS 13.6.3
Protools Studio 2023.12
Antelope Orion 32, Vienna Ensemble Pro 5,
UAD Quad PCIe
Old 09-17-2006, 05:44 PM
I stand corrected. Indeed, the Vari-Speed setting on Time Shift is exactly what I was looking for!
Color me gun-jumping.
I wish I knew how to write my own plug-ins. I'll have to take a class as well!
BIG BUG: Wrong playlist calculations when using AS Pitch 'n Time or Avid Time Shift Franco1967 Pro Tools 11 1 01-25-2014 11:31 AM
PT8 - Pitch 'n Time LE and Time Shift - very slow to operate Richard901 General Discussion 3 12-30-2008 09:00 PM
Pitch/Time Shift glitches in PT 7.4 aperez 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-23-2008 09:04 AM
Time & Pitch Shift Question! Ika 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-19-2008 01:10 AM
Time stretch and Pitch Shift ModaRecords Pro Tools TDM Systems (Mac) 10 12-31-2004 02:53 PM
