Erratic \"Solo\" Track Functionality
Hello,
Has anyone experienced erratic behavior with the Solo track button in either the Edit or Mix windows? The Solo track button behaves normally in most sessions. However, in some of my sessions, the Solo track button either doesn't work at all or it solos ALL tracks. I have checked the Operation settings in other normal behaving session with no luck in finding the answer. This seems very strange. Thanks TonyVT |
Re: Erratic \"Solo\" Track Functionality
Hi!
Check Groups, and also check to see if they are "greyed" out. Either of these conditions would explain this in a heartbeat.
nikki k Eagles may soar, but weasels don't get sucked into jet engines. On the other hand, you have different fingers. |
HI and thank you for your reply. I only have one group, (ALL). It is not greyed out. Also, I noticed that the Solo ONLY works on an Audio track and NOT a MIDI track. I must be missing some very basic here.
Thank you, TonyVT |
have you had problems with mutes too? there's a semi-known issue about mutes not muting properly. i don't think you're the first guy to complain that solo doesn't work right either. the mutes problem seems to be connected to rewire. are you running any rewire apps when this happens?
i love my apple iPhone! |
I've had some really weird glitchy stuff happen too. Closing and re-opening PT usually clears it up. Sometimes its operator error (in my case anyways!) like with a send or a bus.
DaBasstard-
What DaBasstard is referring to is discussed in this thread: Here
rh music |
Hi and thank you for replying.
No, I am not having any problems with the Mute Track button. The Mute Track button works on both Audio and Midi. The Solo Track problem that I am having will not Solo a Midi track, only Audio. Lastly, I am not using any Rewire devices. Thanks TonyVT |
Yes. You were correct. That was a dumb mistake. I am coming from the Cubase SX version 2 environment. I am still getting used to setting up an aux track to deal with the Midi.
Thanks again, TonyVT |
Send mute/solo follows track mute/solo pre-fader | Roger_Jam_Jet | Windows | 3 | 09-24-2017 01:59 PM |
Click track erratic in Pro Tools 7.3.1 | mbender | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 09-03-2013 05:09 PM |
Click track erratic, transport juddering | marcw8087 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-05-2007 06:05 AM |
PT7, Solo a track during a mix | aminusproject | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-11-2005 03:10 PM |
solo a track | srsoundlab | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-27-2005 01:32 AM |
