Recommend a good FX box?
In my attempt to increase CPU power, I'm looking into external FX units. How many of you guys are using external boxes? just wondering....
Also, which would you recommend, in the $500-$1000 range? I'm working on pop/R&B stuff, so some fresh, up-to-date FX would be cool, along with standard verbs 'n stuff. I'll probably use it mostly on vocals, and occasionally on guitars, or ? Should I get a dedicated unit? or is a multi-FX unit cool? (this would be in addition to the Waves Gold pkg) |
Re: Recommend a good FX box?
I know this unit is a bit more money than you want to spend, but you might consider the tc Electronics M3000. In addition to having two simultaneous very pro sounding STEREO effects, it can also serve as a superior 24 bit stereo A/D converter. It has built in d'essing and compression and will communicate with 001 through either adat optical, toslink, or S/PDIF.
Just a thought...
Through the power and charm of music the spirit of man is uplifted. `Abdu'l-Baha |
tc electronics m-one 499
yes, I've heard good things about the TC stuff.
Anymore suggestions? |
Roland SRV-3030. $300 for the analog i/o version, $400 for the sp/dif digital version.
a $120k business degree will get you a job on Wall Street - a $120k Berklee degree will get you a job on Beale Street... |
A good reverb you could recommend. | GtrDude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 12-16-2008 02:15 PM |
What do you recommend for a good D.I. Box? | dougied | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-14-2008 09:59 AM |
Please recommend a good sampler . . | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-25-2008 12:26 PM |
Can anyone recommend a good DI box? *URGENT* | Kleekoh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-04-2003 08:43 PM |
can someone recommend a good book.... | Maurice_Green | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 01-30-2002 10:23 AM |
