Problem with sound after bouncing to disk from PT11; audio included
Hi guys, here's my setup:
Intel(R) Core (TM) i7-2600 CPU @ 3.40GHz 3.70 GHz Windows 7 Ultimate 64x Pro Tools 11 32GB Ram Komplete audio 6 interface, USB2 PT11 installed on 500 GB NTFS SSD And the project in question is 48kHz, 24 bit, bounced to the same (and I get this problem with all file types and bouncing on or offline). I can't really describe the problem accurately; its sort of a high pitch resonance that I only hear after bouncing down out of PT11, it sounds fine while in PT. It always seems to effect the left channel far worse (switching monitors (KRK RP5s) doesn't help, so fortunately they seem to be fine). The uploaded audio files are me playing a recorded clip in PT, then what it sounds like after the bounce. I don't think I'm exporting at too high a volume, the second chord which clearly demonstrates the problem is at -15 on the master level meter. If I import the bounced track back into PT11, the problem disappears. Any advice on how to have my bounced files sounding as they do in PT would be greatly appreciated! Here are the recordings that demonstrate the problem. I recorded them with windows sound recorder, I just put a condenser mic right up to the most offensive monitor: Sample of recording in PT, prior to bounce: http://www.filedropper.com/inpt Sample of recording out of PT, post-bounce: http://www.filedropper.com/outofpt |
Re: Problem with sound after bouncing to disk from PT11; audio included
do you have it in surround mode?Someone else was having problems like this and I believe they were had surround checked on the second page
For what it's worth to anyone else with a similar problem, my computer engineer brother thinks my audio interface is broken in such a way that it manages to cause this problem only when I play stuff outside Pro Tools. Will be testing this shortly. |
the second page in the bounce to disk mode has a setting for surround I think.?Also are you making an MP3..If so on the second page make sure your at 256 on your constant bit rate
I guess I'm missing something quite big. When I bounce to disk, I go to File -> Bounce to -> Disk... and the following window comes up:
Except of course it has the Windows border for me. But this is all I see, there is no second page with a surround sound option. How do I go your route? Thanks for your help by the way! |
According to the image you provided, you are bouncing as a multiple mono file. Have you tried bouncing as a stereo interleaved file? Since you are not changing the sample rate or bit depth, rather than bouncing, why don't you try exporting the audio clips (in the edit window, on the list of audio clips on the right hand side of the screen, select the clip and left click (I think), and it should bring up a list of actions, including export clip). Try that method and see if the problem goes away. If not, it may be your interface as you suggested.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
Why does it sound totally different after bouncing to disk? | John Beef | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 01-25-2016 02:33 PM |
Problem with sound quality after bouncing to disk | RogerC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 01-26-2007 04:17 PM |
bouncing to disk problem or? | universe777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-12-2006 02:00 AM |
Problem Bouncing To Disk | Stixntrixx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-29-2006 04:08 AM |
bouncing to disk problem | johnmo2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-15-2004 10:29 AM |
