Old 06-22-2013, 12:31 PM
Actionmusic Actionmusic is offline
Default Track Preset hack - PT11 edition
What a chaotic day ! But here's a ray of sunshine for those that managed to install and get the assets for 11
Track Preset Hack seems to work in 11, albeit slightly differently. Great , as this had become a big part of my workflow.
Mac for me -
Right click Pro Tools (64 version) icon
Show Package Contents
Open folder Contents
Down to "Shared Support"
then open "Factory Content"
Create a new folder in there exactly named "Track Presets"
In that create your folders e.g. "Synth Setup"
and in that have your session template .ptxt file you've exported or converted
Folder contents sessions then appear as an option on the New Track menu
So pretty much the same methodology as before but a new place.
I did this on the trial btw (first thing I tried!). Thanks avid
Old 06-22-2013, 12:47 PM
mykhal c's Avatar
mykhal c mykhal c is offline
Default Re: Track Preset hack - PT11 edition
yep...there's a new location for this on the W7/W8 side too. i cannot recall new location offhand...not at rig. will post back if no one else post new location...
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
Old 06-22-2013, 03:33 PM
YYR123's Avatar
YYR123 YYR123 is offline
Subscribing....Thanks I was under the impression that this was a no-op....
I wonder if they put the info in the ref manual
Daniel
Old 06-22-2013, 05:08 PM
mykhal c's Avatar
the default location for this in W7/W8 is...
Documents Library>Pro Tools or
Documents and Settings\(user)\My Documents\Pro Tools (for absolute path)
and remember this is user definable in Prefs.
Old 06-22-2013, 05:23 PM
zedhed's Avatar
zedhed zedhed is offline
Originally Posted by GregJ View Post
Here's the path for the Track Presets Folder in Windows 7:
C:
Program Files
Pro Tools
Factory Content
Place the folder titled "Track Presets" inside the Factory Content folder.
I did a copy/paste of my Track Presets folder that I already setup in PT 10.
Hope this helps.
So which one is it?
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 06-22-2013, 05:30 PM
mykhal c's Avatar
Originally Posted by zedhed View Post
So which one is it?
it's what i said...but you can define it to be whatever. check Prefs...you'll see then...
Old 06-22-2013, 05:40 PM
zedhed's Avatar
k thanx.
HD 96I/O
Old 06-23-2013, 04:04 AM
Mac for me -
Thank you greatly! I started another thread here on this: http://duc.avid.com/showthread.php?p...16#post2051916 and it was driving me nuts considering how much PT11 (demo here as well) shared in preferences and folder locations with PT10. Does the same process for creating them work in PT11 as it did in 10?
Jack
QAPLA!
Old 06-24-2013, 05:36 AM
I give up. I followed the instructions about adding a folder called Track Presets as in the first post in this thread. I then copied over all the presets and folder structure I have for PT10 to this new folder, effectively having two folders with the same presets but one for PT10 and one for PT11. Those all work fine.
Where I'm having a problem is in creating new ones from inside PT11. No matter what technique I use to create the new preset (there's actually a couple of techniques) when I go to save it and go to create a new track with the just created preset that new preset can't be found. Thing is you can't navigate to the newly created Track Presets folder from within a normal Finder window you have to dive through the procedure outlined above. So I tried creating an alias to the newly created Track Presets folder but saving via that path doesn't work. I can see the new preset there but it doesn't appear when I go to create a new track.
The two techniques I talked about above that work for me in PT10 are to either save selected track as a template or to save the selected track as a new session and then go in via Finder and change the extension to .ptxt
Edit for additional:
I was able to see the newly created track in the New Track window but had to quit PT11 and then restart. Don't have to do that in PT10. What a pain in the arse.
Jack
QAPLA!
Old 06-24-2013, 06:13 AM
mrjohn mrjohn is offline
Thanks for the tip! After creating the Track Presets folder and before adding any presets I noticed that in myusername/Documents/Pro Tools there is a folder called Track Presets. So I put them in there and it worked!
Don't know if that folder was there before though as I hadn't looked. If it is there by default then that would seem easier than opening up the package and messing with that.
John
Mac Pro 2 x 2.8GHz Quad
OSX 10.10.5, PTHD 12.4.0
Track preset Hack questions Suke Tips & Tricks 2 01-12-2016 04:26 PM
Can't see Channel Strip plugin controls (Track, Preset, Auto Map, Bypass, etc). DJ Hellfire macOS 9 05-09-2015 08:38 AM
How are you using the track presets 'hack'? kmoneybts Tips & Tricks 2 09-02-2013 03:56 AM
PT10 Track Preset mehrdadp Eleven Rack 1 12-16-2011 01:21 AM
record preset drums beats on a instrument track. Need help K2warcrew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-03-2007 11:11 PM
