master fader output w/ headphones one
when I make a master fader. it does nothing
I'm working out (monitoring) of the headphone jack is there something in the I/O I have to changed? Can I change the master out to headphones? or vise versa? because when I go to another system not using an omni I have to change everything out to master out on every track (the headphone is shaded out)
windows7 HP XW8400 Workstation Xeon Dual-Core 5150 2.66GHz 12gig ram |
Re: master fader output w/ headphones one
Check what the output is set for on the master track. Odds are its not the same output as the rest of your tracks, OR, your headphones are not being fed by the main outputs(in which case, you should set the master track output to the output(s) feeding the headphones.
Master fader final output level | bryced87 | macOS | 5 | 04-22-2013 05:10 AM |
Basic Gain Structure Fader/Master Fader Question | acmost | Pro Tools TDM Systems (Mac) | 1 | 05-16-2011 05:36 AM |
Output level/Master Fader conundrum... | jensen5 | Pro Tools M-Powered (Mac) | 2 | 05-30-2005 10:41 PM |
Routing output of master fader | MPB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-14-2003 12:44 PM |
No output to 1622 *and* master fader shows output? | nettwerk | Pro Tools TDM Systems (Mac) | 1 | 10-30-2000 05:35 AM |
