Old 06-10-2012, 01:23 PM
xeligio xeligio is offline
Default Video BUG in PT10
Hey,
I am mostly using PT for music, but occasionally i do some postproduction and video. All was good on PT9, but i have (unfortunately?) upgraded to PT10 and today had first session with video... it did not go well. As soon as i load video track, PT slows down...way down. It is impossible to do any editing on audio or midi, because if i click on a clip, it takes about 1.5 second until it is selected... if i click and drag it, there is no control over it as the delay is unbearable, when i want to drop the clip in new place, it doesn`t show it so i can`t see where it is going... hard to describe, but basically it feels like comp is maxed out and doesn`t have resources for redraws.. but the system usage shows around 2%! And I know this is not the issue of cpu, the session is way too simple for that. And the best thing at the end: when I actually play the session, everything works great, clips moving instantly etc.! As soon as I stop, back to delay. Does anyone have a clue what`s going on? Win7
Old 06-10-2012, 01:39 PM
WolfieCAL WolfieCAL is offline
Default
I have the same problem if a client sends me a file in a very large resolution. Use QT Pro or similar software to adjust the resolution.
Sent from my iPad using Tapatalk HD
Old 06-10-2012, 02:17 PM
Default Re: Video BUG in PT10
Thanks Man, I am going to give it a try
Old 06-10-2012, 02:23 PM
What other similar software (than QT) would work well? I just can`t digest this Apple
Thanks
Old 07-17-2012, 12:12 AM
Peter Groom Peter Groom is offline
Can I presume that you have
pt software on the system / c: drive
Audio on a different physical drive
Video on a different drive also.
Peter
Old 07-17-2012, 02:54 AM
browniespeaks browniespeaks is offline
Default
Mwah ha ha ha you can not.
Sent from my SGH-T769 using Tapatalk 2
Clifford Brown III
Brown Audio Solutions & Services
www.brownaudio.com
PT10 Video sync issue Crossleyj Pro Tools 10 4 09-16-2013 08:42 AM
PT10.3.4 and Video Engine Win 7 only Buccanears Post - Surround - Video 3 03-13-2013 02:58 PM
Import multiple video help on PT10 you kay Windows 3 03-04-2013 08:17 AM
Video In PT10 mkegvn Pro Tools 10 6 12-19-2011 06:56 PM
Why no new video card support in pt10???? diamondschwin Post - Surround - Video 2 10-21-2011 08:36 PM
