Old 03-10-2012, 05:40 PM
DonaldR DonaldR is offline
Default Eleven Rack & in-ear monitoring
First post for a future owner of an Eleven Rack (I have Digi-001 for more than 10 years).
After reading many post on this forum and other ones on the net, I concluded that I don't what to go traditional amp/cab route. So I want to go with FRFR for band practice (which I already have) and in-ear for live show.
I have zero experience with in-ear. I already have a set of Shure E1 in-ear monitors that I will use for now and will upgrade later-on (if needed). I only do small gigs 4-5 time per year.
Question 1: what wired receiver/transmitter are you using?
Question 2: what wireless receiver/transmitter are you using?
Question 3: would it be great (as a wired in-ear monitor without additional hardware) to simply use the line-in of eleven rack and mix it with full rig on ER headphone out?. Avid can only add a mix level and a brickwall limiter as part of next upgrade (can also serve as an aux input to practice with ipod/iphone).
Old 03-10-2012, 05:50 PM
moff moff is offline
Default Re: Eleven Rack & in-ear monitoring
I WAS using a Shure PSM400 system, with the optional 4-channel line mixer\splitter. The original E3 earbuds were only OK at best, so I upgraded Shure SLC5s (dual-driver).
Then the FCC and the CRTC/Industry Canada reserved the "700 MHz" band (698-806 MHz) for emergency use only, making my Shures illegal for use here or in the USA. At that point, I purchased the Sennheiser IEM 300 G3 system, which I love to death - especially with the SLC5 earbuds.
I can't speak about wired in-ear systems...
Eleven Rack questions - monitoring & rig settings mrllnfn Eleven Rack 2 02-20-2013 09:25 PM
Eleven Rack monitoring? saheyl macOS 1 02-01-2013 10:53 PM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Vocalrecording - Eleven Rack - Low Latency Monitoring? wiseman Eleven Rack 8 07-01-2011 06:52 AM
Eleven rack and cubase : monitoring problem Holyoli Eleven Rack 1 10-10-2010 03:49 PM
