Old 11-07-2010, 06:10 AM
@tention @tention is offline
Unhappy Can't get 2.5.6. to work :-(
Hi forum,
I'm trying to get 2.5.6. to work but the workstation will not attach to the EuControl software. When I revert to 2.5.5. all is well and EuCon finds and attaches the workstation just fine (apart from PT 9 not working with this release....).
I have tried this on two different machines running 10.6.4. (System language is German) I have Mix, Transport and Control hooked up via a gigabit switch.
Ollie
Old 11-07-2010, 02:40 PM
mix109 mix109 is offline
Default Re: Can't get 2.5.6. to work :-(
I dont have PT9 Installed but i also had to rollback to 2.5.5 once nothing but nothing worked with 2.5.6....
PT L e 8.0.4cs4 and Nuendo 5.1(with EuCon licence) and a single MCMix on 10.6.4._connected to EnetP1
Avid:Any feedback_comments?
Noiselab Noiselab is offline
All of a sudden, I'm in the same boat as you Ollie. The big difference is that I had it working last night with PT9, EuCon 2.5.6 and the firmware updated in both my MC Mix and MC Transport. Hardly any fuss at all.
When I fired everything up this morning, I cannot get either Artist Series device to acknowledge PT9 or vice versa. The only change that I'm aware of was a shut-down for the night. I've re-installed EuCon AND PT9 twice with no joy.
HELP! PLEASE!
NL
Old 11-07-2010, 02:51 PM
Gemylon's Avatar
Gemylon Gemylon is offline
First...
* Installed 2.5.6
* Then I deleted ALL Eucon pref. files in BOTH Libraries, (Main + User lib)
Then...
* I deleted ALL ProTools prefs,
* I re-installed ProTools 9,
* I repaired permissions.
* Restart, and finally...Everything work as it should !
Hope this helps ...
G
Old 11-07-2010, 03:27 PM
Gemylon, that was the ticket! I'm operational again!
I'd killed the EuCon .plist files in the main Library but not in the User Library previously. Wow!
Many thanks!
NL
Old 11-07-2010, 03:48 PM
Carlos Juvandes Carlos Juvandes is offline
I'm going to try that tomorrow.
Thanks
MacPro 2.8 8core|PT 11|3xUAD-2|2xMC MIX
Thermionic Phoenix Mastering Plus|Manley Massive Passive|API 2500|Distressor EL8-X|Summit TLA100
Old 11-08-2010, 08:52 AM
marty martin marty martin is offline
That's got it for me too!
Deleting the preferences.
Why didn't I think of that?!!!
Studio: Mac Pro Trash Can 2.7 Ghz, 32Gb RAM, Sonett xMac Pro Server, HDX 22.12, S6 M10 24 Fader, Rednet 5,1 and 4
Live: MBP 16" M1 Max i7 32Gb RAM,
Old 11-09-2010, 08:53 AM
Now it works.
I didn't repair permissions and didn't install Protools again.
Just trash the preferences and install it again.
Old 11-09-2010, 09:46 AM
Thumbs up Re: Can't get 2.5.6. to work :-(
Thanks everyone, I've got it working now.
Old 12-30-2010, 10:49 AM
Gemylon's Avatar
Well, I had it working a while back...
Now,
I am having some main issues with connecting to my Artist series.
I have a MC Control and 3 MC Mix.
When opening the EuControl Settings panel,
most of the time there is no Workstation in there.
And if there is, and I try to attach it, it just disappear.
I have tried everything.
I ave trashed Preferences in both Libraries,
and both Euphonix and ProTools.
I have installed both EuControl and ProTools over agin, but nothing helps.
I have also done the Network Connections procedure form scratch again.
I am using MacOSX 10.6.5, ProTools 9, and EuControl 2.5.6
Running a MacPro with 18 GB RAM.
So any idea where to go from here ?
G
Audio Suite plugins that work in 10, do they work in 11? David Sandwisch Windows 1 08-10-2013 08:14 PM
The plugs that WORK and DON'T WORK on 7.0 The Mink 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 02-10-2006 10:12 PM
New Mic won't work DougSt.Louis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-12-2002 09:06 AM
How does Direct Connect work?? (Does it work well??) tommydee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-18-2001 08:13 AM
