Old 11-02-2010, 02:13 PM
blast9 blast9 is offline
Default Error message "could not complete your request because..." on PTLE 8.0.3 load up
Hi -
PTLE 8.0.3 CS2 on Digi approved Lenovo T61 Laptop, Vista Business SP2
originally had 8.0.4 but had problems
Digi 002 and/or Mbox Micro.
(This setup was working fine)
Installed
today an expresscard slot and an SIIG 2 port firewire expresscard because (as expected) I had problems with deteriorated firewire disk performance.
Have not used PT for 6 weeks and on booting it I get this message:
could not complete your request because assertion in "..\..\Sys\Sys_FileLoc.cpp", line 241
trashed prefs
Reinstalled 8.0.3... tried launching - same message... then CS2 update - same message.
Disk is not fragmented
device manager reports no hardware errors
Message occurs with or without the FW expresscard... i.e. 002 attached directly to internal FW port ot via expresscard
message occurs either with 002 or mbox micro attached
Old 11-02-2010, 02:49 PM
Default Re: Error message "could not complete your request because..." on PTLE 8.0.3 load up
OK - update - this seems to be user related.
It only occurs when logged in as administrator... which is weird -
Previously I only ever ran PT logged in as admin
if I am logged in as normal user I can launch and run with no errors.
"Could not complete your request because Access is denied" ColinSound Windows 2 05-13-2013 02:58 PM
FIXED: Startup issue: "Could not complete request because Assertion line 1424" wheret Windows 2 07-11-2012 05:43 PM
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... tohmit macOS 5 03-23-2011 12:13 PM
"could not complete your request because end of stream encountered" PT8 promblem nikokarpaasi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-22-2009 12:49 AM
"Cannot complete request... Access violation occured" jonnyb8390 Pro Tools TDM Systems (Mac) 0 01-07-2009 12:39 PM
