Problem with direct monitoring in Cubase
Hi everybody, here's my problem :
I'm on Windows XP sp3 I've got the RME Octamic plugged into the Digi003 via ADAT when i want to direct monitor my inputs in Cubase, i can see the input signal on my audio track, but there is no sound... I really don't see where the problem is, so please help me ! Thank you in advance, Nico. |
Re: Problem with direct monitoring in Cubase
Have you checked the Cubase forum? This really is a Cubase issue. With that said, are you sure you have the routing correct? With that said, I'd not depend on the 003 to provide a great Core Audio device with your Cubase software.
yes I checked on the Cubase forum, but noone to solve my problem.
My routing is ok, I think I checked everything, as I said I see the input signal on my channel strip but can't hear a thing. is it impossible to direct monitor the digital inputs of the Digi in Cubase ? |
Direct Monitoring in Cubase only works with audio interfaces that specifically support that feature, which none of the Avid/Digidesign interfaces do. I think there's only a handful of interfaces that support it and RME might be part of that handful...
Cubase 5.5.1 :: Ableton Live 7.0.18 :: Pro Tools M-Powered 8.0.4 Windows XP Home SP3 :: Gigabyte GA-EP45-DS3R :: Core 2 Quad Q6600 2.4GHz :: 4GB DDR2-800 Mac OS X Leopard 10.6.4 :: Macbook Pro 2.16GHz :: 3GB DDR2-667 Access Virus TI Polar :: M-Audio Profire 2626 :: UAD-2 Duo :: UAD-1 |
Turn on the monitor button on the track you're recording to in Cubase, if I remember rightly, it's just under the record button on the mixer. I'm not at home so I can't check for you, but I use a 003 with Cubase a lot and I use the mixer in Cubase to set monitor levels etc. Doesn't seem to be any noticeable latency. Almost forgot, you need to have direct monitoring checked in Cubase preferences. One thing I know is that there is some recording delay in Cubase which needs to be adjusted for, I think mine records 18 milliseconds too early, really annoying. Good luck
ASUS P5k, Win 7, RME Multiface Macpro, 10.8.3, Digi 003 Profire 2626 PT 10.3.6 |
Cubase 'direct monitoring' with HD Omni ? | kick56 | Pro Tools HDX & HD Native Systems (Mac) | 1 | 04-07-2012 03:32 PM |
Direct Monitoring on MAC | carbarnrob | Pro Tools 10 | 0 | 10-24-2011 11:18 AM |
Eleven rack and cubase : monitoring problem | Holyoli | Eleven Rack | 1 | 10-10-2010 03:49 PM |
digi002 and direct monitoring in cubase etc... | fonografist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-13-2008 08:23 AM |
Direct Monitoring in Cubase... | Carlos Juvandes | Pro Tools M-Powered (Win) | 1 | 09-24-2007 12:59 PM |
