Old 04-24-2010, 09:06 AM
Alécio Costa's Avatar
Alécio Costa Alécio Costa is offline
Question Evaluating Autotune 5 TDM with PT 8 HD
I was requested to use that T-Pain Effect with Autotune 5.
I downloaded the demo, so considered buying it. However, It keeps making some glitches as If audio regions had bad crossfades.
a)I consolidated files and these clicks still continued
b)I disabled quick punch, loop playback and no sucesss.
c) I enabled/disabled Delay compensation Short and also no success at all.
Funny is that if you play the same section several times, sometimes it does not click and in others, it clicks.
File is not clipped and my MAC 2007 Pro 2.66 Quad has 5GB of RAM.
I use heavier plug-ins like Neon HR (RTAS) or Revibe and I never have these clicks.
Also, I opted for Autotune 5 instead of Autotune 6 because one funnction of its Preferences has been eliminated in Autotune 6 Evo.
SO.. will I have to change Host Processors, HW Buffer Size, CPU usage çlimit and Size to work properly?
At the moment HW Buffer Size is at 512, Host employing 3 processors, CPU Usage at 95%, 48 voices, Delay Short, SIze Level 2, Cache is normal.
The site does not mention which OS version is more appropriate for Autotune 5.
I am with PT HD 8.0.1cs3 OS 10.5.5 - PT HD2 Accel PCI-E.
Thanks
Alécio Costa Studio
High-End e-Mastering & Music Production
www.aleciocosta.com
http://www.facebook.com/alecio.costa
PT Ultimate Native 2023.3 - Mac Mini M1 16GB RAM - Mac Os Ventura 13.2 - 2 192 IO Digidesign Digital
PT HD2 Accel - 10.3.10 OS 10.6.8 - Mac Pro 2008 16GB RAM
Mastering Gear: Pendulum Audio, Crane Song, Avalon, Great River, Sebatron, Sonnox, Izotope, PSP, TC, Fab Filter.
Old 04-24-2010, 09:14 AM
studiojimi's Avatar
studiojimi studiojimi is offline
Default Re: Evaluating Autotune 5 TDM with PT 8 HD
i have AT6 EVO
i use it when requested under protest.
but sometimes you can do some creative twisted sick little things
the optimum word is sparingly..... (and sometimes gently)
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 04-24-2010, 10:08 AM
elicious elicious is offline
hi alecio,
we have very similar specs as you
and have both evo & at5, however both rtas.
for evo, tdm is crippled;
lacking real time pitch shifting,
formant correction,
& throat modeling.
i have also seen other users post with evo tdm buggums
here, both plugs work smooth.
also, if you purchase evo
it comes with ver5 included.
the biggest diff for us in evo was the improvement in tracking;
less octave switching.
but add to that real ability to copy/paste
set your own keyboard shotcuts,
resizable gui,
better transposition quality,
object based retune speed settings
and the new note tool has sped up our workflow considerably.
so, i'd suggest trying/buying evo native;
getting 5 for free,
only downer is evo sucks about 100mb of ram each instance.
otherwise, solid.
b.o.l.
e
e.p.s. which pref are you missing from 6?
ihatetyping
Old 04-24-2010, 10:56 AM
I didn´t know buying Evo6 we would take 5 for free.
But when using TDM, have you guys changed those parameters dramatically?
A few rappers like to track while listening to the output of Autotune!! So TDM seems to be a much better solution.
I will also evaluate the lighter version, Autotune EFX version.
In fact I was more satisfied with Melodyne .
I will retry today doing the bounces with different settings. What a drag...
Thanks
Alécio Costa Studio
www.aleciocosta.com
Old 04-24-2010, 11:10 AM
Mt.Everest Mt.Everest is offline
Originally Posted by Alécio Costa View Post
What function in the prefs were eliminated? I was about to upgrade my Evo5 to 6 but Im curious what function was removed now.
Thx
MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O
PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8
PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626
•••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!•
Old 04-24-2010, 11:36 AM
hey a, you may already know this,
but stick a tdm plug in bypass b4 your instance of a-t native
and you can trak through it fine.
(may need to adjust your buffer a bit...)
e
ihatetyping
Old 04-24-2010, 03:39 PM
Sure I do Know.. But thanks for your consideration and attention!
Alécio Costa Studio
www.aleciocosta.com
Old 04-24-2010, 03:40 PM
A RAP producer told me the slider function at the Option page is not longer at AT6. ( I forgot the name of the function).
Alécio Costa Studio
www.aleciocosta.com
Old 04-24-2010, 04:02 PM
studiojimi's Avatar
e
.....or just use a very low usage one like Trim
CAZADOR RECORDING
Evaluating PT10 Trial: Alphatracks and Tranzport Dave Modisette Windows 1 06-05-2012 06:29 AM
AutoTune 5.06 available now Studio Dweller Pro Tools TDM Systems (Mac) 3 12-12-2006 01:29 AM
AutoTune 4? Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-12-2004 02:13 AM
evaluating near field monitors davidp158 General Discussion 32 08-29-2001 06:16 AM
Evaluating room acoustics and treatment davidp158 General Discussion 4 08-28-2001 01:12 AM
