Phase invert and -10/20db pad?
Does or doesn't the new C24 (which I own) have phase invert and -10/20db pad on the input stages? If it has I must be really stupid cause I can't find it, I'm recording drums and almost every channel is clipping at 0db gain. The reference guide mentions this BUT only regarding the "Digidesign PRE" unit in interaction with C24:
Re: Phase invert and -10/20db pad?
Yes. That information is only for controlling the Digi PRE via the C|24. If you want pads and phase inverters on each channel, then yes, XLR pad adapters are in order:
http://store.digidesign.com/us/index...roductid=62786 |
With this type of gain structure, the C24 absolutely should have included at least a pad switch, if not a phase invert switch as well. At the VERY least, they should have included 16 of the M-Audio in-line pad/phase inverters mentioned above, which list at $25 each.
Phase Invert on the 003 | thebreaksnyc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-26-2011 02:18 PM |
How do you invert phase in PT? | Gunnell | Pro Tools M-Powered (Win) | 1 | 11-14-2006 08:11 PM |
invert phase help | keithaska | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-07-2006 05:09 PM |
Phase invert | Mateus Borges | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-18-2005 08:42 PM |
How do you phase invert?... | marcelloz | Tips & Tricks | 1 | 07-12-2001 07:13 PM |
