+12db/+6db
Just curious...when you open an old session and you get the dialog box that asks if you want to keep it at +6db, being somewhat afraid to fix what ain't broke, I generally leave it at 6. Is there any advantage to opening it at +12?
Re: +12db/+6db
Not unless you need +12 gain on a channel!
Re: +12db/+6db
Is there any advantate in using 12db fader gain over just inserting a trim plugin,(other than the small amount of dsp trim uses)?
Re: +12db/+6db
STeve
macmandigital.com |
Re: +12db/+6db
Hey Steve,
I wish the automation on the trims was sample accurate like on the faders. It's becoming more and more common to copy the editor's volume graphing to trims and then blowing out the fader automation for film mixing on an Icon and starting with the faders @ 0 and using them to trim the editor's moves (especially for temp dubs). You end up having to move the trim gain automation breakpoints a frame or so earlier to give it time to get there in time. Joe |
Re: +12db/+6db
I always thought it would be a good idea for Digi to have several additive volume graphs per fader. Then you could have rides that the editor did on one layer and have the mixer's rides on another, and then the actual gain would be a composite of both. I often do surgical rides carefully trimming the breakpoint line to even out the bumps and lumps, but then on top of that you need the perspective of realtime hand rides within the track. It would be great to keep those seperate without having to buss to an aux or copy to the trim plug-in. Then when you liked everything you could merge the automation. Of course sample accurate plug-in automation is badly needed. Not only for trim plug-ins, but for automated eq as well. STeve
macmandigital.com |
192 A/D D/A -12db modified??? | corp | Pro Tools TDM Systems (Mac) | 0 | 12-25-2010 09:35 AM |
How to set fader to 6db not 12db | Greene | Pro Tools TDM Systems (Mac) | 1 | 04-21-2008 12:52 PM |
PLEASE HELP! 10.3.9 w/ C24, v6.4.1- 12db issue | muselemuse | Pro Tools TDM Systems (Mac) | 3 | 05-25-2005 11:17 AM |
Should I choose +6dB or +12dB ? | jmsx521 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-09-2004 09:55 AM |
001 Outs 3-8 down 12dB | CLanger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-02-2004 06:41 AM |
