Old 01-08-2005, 09:17 AM
UTS UTS is offline
Default Firewire Drive w/ Mix System
Hi there,
I have a Mix System consisting of Mixfarm/D24/DSP Farm on a B/W G3 on OS 9.2.2 with 896 MB Ram. I have a Firewire drive (80 GB) attached which should meet the specs (7200 rpm) but I get Disk to slow or too fragmented errors all the time. Did anybody have luck with Firewire on B/W G3? If so, which drives/and or Pro Tools Settings do you recommend? I thought about partitioning the drive could help for better performance...is that right? If so, which tool do you use to partition drives on OS 9 and how do you do it?
Thanks for your help,
Markus
Old 01-08-2005, 03:27 PM
tuchel tuchel is offline
Default Re: Firewire Drive w/ Mix System
I used (and still use, though I have a G4) firewire drives with the oxford 911 chipset with my 350 G3. That was the key for me, never had any trouble with those drives. You can find them most anywhere, but I bought mine here: http://www.owc.net/
tuchel
Old 01-08-2005, 03:46 PM
boneboy boneboy is offline
Do the Glyph firewire drives have the oxford 911 chipset?
Thanks
Old 01-08-2005, 08:26 PM
Nick Batzdorf Nick Batzdorf is offline
Firewire can do that sometimes. I haven't noticed this very much recently (possibly because of OS X?), but you can have two of the exact same model drive and case, and one will never complain and the other will disk-too-slow you to death.
The only solution when that happens is to split the audio over two drives. Restarting Pro Tools works for a couple of minutes but then it happens again. Always.
Old 01-08-2005, 08:27 PM
Thinking about it, I'm very sure it's OS X Panther that's improved things, because I'm not using any new drives for recording.
Old 01-09-2005, 11:06 AM
MARVINBASS's Avatar
MARVINBASS MARVINBASS is offline
Thanks
Yes they do, and a matter of fact, they were the first to intoduce firewire for Audio. I use them exclusively and never had problems with them. (My 2¢)
My System is:
Mac Pro 3.2GHz 6 Core
32GB RAM
1- HDX
1 - Apogee Symphony Mk2 8x8
1 - HD 16x16 Interface
MOTU MTP/AV
Second System
Mac Pro 2013 3.5GHz 6-core Xeon E5-1650v2
32GB RAM
1 - HDX
1 - Avid Thunderbolt 3 Expansion Chassis
1 - HD 8X8 Interface
MARVINBASS Digital Audio, LLC
Ex PT Beta Tester
Woodland Hills, CA.
Old 01-10-2005, 05:02 AM
UTS UTS is offline
I bought a new enclosure today with the Oxford 911 chip and - voila!- all problems went away! So if anybody is experiencing firewire weirdness...go and get an enclosure with that Oxford chip!
Best and thanks alot for your help,
Markus
OSX + PT HD system on firewire drive songman Pro Tools TDM Systems (Mac) 7 03-23-2007 07:51 AM
Firewire drive vs system drive Cliffy_Boy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-25-2003 01:10 PM
How can you use an external firewire drive and Digi002 with only 1 firewire port? CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-16-2003 01:11 AM
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be Fucius General Discussion 4 03-19-2002 11:26 PM
scsi ultra160 disk for system drive and audio drive jazzle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-23-2001 06:54 AM
