  #261
Old 03-11-2024, 10:03 AM
Default Re: MacOS Sonoma
It's just because not everyone have these wicked fast Apple Mx series internal storage, where it really does not matter.
Back in the DigiDesign days we were given specs like "for X amount of tracks you need Y amount of 7200rpm hard drives with latency of Z milliseconds or smaller". Not anymore, you test how much disturbance your system can handle.
  #262
Old 03-11-2024, 11:37 AM
Max4992 Max4992 is offline
Originally Posted by JouluPam View Post
Hi all!
After upgrading to Pro Tools 2024.3 moving clips and fades around causes the transparency effects to flicker, along with the clips them selves. Very annoying. Anyone experiencing the same issue? Any help?
I'm on Sonoma 14.4. Didn't happen before 2024.3.
Thanks.
System Details:
MacBook Pro 16-inch, Nov 2023
M3 Max, 16 (12/4) Core CPU
40 Core GPU, 128 GB RAM
macOS 14 (Sonoma)
Pro Tools Studio
Perpetual License
w/Update & Support Plan
Yep I'm having the same issue. I have all the Mac OS "perks" turned off as well (ie continuity camera, handoff, etc.).
Very glad to report the crashing whilst scrolling has been fixed. :)
  #263
Old 03-11-2024, 12:04 PM
TrentWilliams TrentWilliams is offline
Hey all,
Is anyone able to confirm the Pace/iLok issue with Sonoma 14.4 is isolated to Silicon Macs only, or is it a Universal Intel/Silicon issue?
Thanks!
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
  #264
Old 03-11-2024, 12:09 PM
No, but Avid/iLok are investigating. Bear in mind, 14.4 is not supported.
  #265
Old 03-11-2024, 12:23 PM
gthm's Avatar
gthm gthm is offline
Originally Posted by darryl ramm View Post
macos systems optimization instructions could do with a clean up, including clarifying whats really recommended and what to try if there are problems (e.g. Disable spotlight indexing).
Yes.
Pro Tools 2024.3
macOS 14.4
iMac (24-inch, M1, 2021)
(16GB RAM, 1TB SSD internal)
Samsung T7 x a few
Samsung 980 Pro x 2 (in Acasis TB/USB 4 enclosures)
Apogee Ensemble Thunderbolt (my hero)
  #266
Old 03-11-2024, 01:49 PM
itsjustmeee123 itsjustmeee123 is offline
I'm right at the point of deciding whether to install Sonoma and if it's worth it. I have an intel 2019 iMac 3.6 8 core with 64 gigs of ram. I'm on Ventura now and it's running fine. I'd just stay with Ventura but I also use Logic Pro and would like to upgrade that (which needs Sonoma). The question is, will I have any performance issues upgrading?
  #267
Old 03-11-2024, 02:42 PM
Check your audio hardware too. Carbon isn't certified with Sonoma (with known problems), as an example.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
  #268
Old 03-11-2024, 03:34 PM
WHelbsing WHelbsing is offline
Upgraded to Somona 2 days ago, couldn´t trust my eyes (well, i use Carbon). Catastrophy. What a ********, surface-wise, performance-wise.
Latest Pro Tools and Logic run fine on Ventura.
I just downgraded to Ventura, everything runs smooth again.
W. Helbsing
  #269
Old 03-11-2024, 08:03 PM
paul_g's Avatar
paul_g paul_g is offline
Originally Posted by tope d View Post
Hi Paul! May we know what you're referring to? the previous response? or the thread itself?
Thanks
The bit above where they mention turning off all the peripherals in Sonoma.
I bet a lot of folks will upgrade and forget to turn off all the Apple Bling (aka bloat).
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
  #270
Old 03-12-2024, 07:47 AM
ralphonz ralphonz is offline
Hi all!
Thanks.
System Details:
macOS 14 (Sonoma)
Pro Tools Studio
Perpetual License
Hi all, I'm getting this issue too. PT 2024.3.0 and Sonoma 14.3.1. Handoff is disabled. There's no camera on the machine. The flickering happens even when there is no tracks armed and PT is not recording, and happens when PT is not even playing back. It just happens whenever a clip is moved.
Edit: So I wrote that post with pro tools open - then posted it and went back to Pro Tools and no flickering. I wouldn't say the issue is fixed but seems intermittent at least.
Edit 2: Then after submitting my edit I go back to pro tools and the clips are flickering when moved again! WTF!
macOS 12.4? off the wall macOS 36 06-06-2022 11:50 AM
HD Hardware (HDX/HD Native) not detected by macOS (macOS 11 Big Sur newstrings Pro Tools HDX & HD Native Systems (Mac) 6 01-15-2022 11:48 PM
macOS 11.6.2? off the wall macOS 9 12-19-2021 08:46 AM
Macos big sur nesseldigital Pro Tools 2020 2 12-27-2020 04:49 PM
6.0 and Macos X gmcgmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-11-2003 09:08 AM
