Old 09-20-2013, 08:22 AM
digimog's Avatar
digimog digimog is offline
Default Apple Mini Recommendation
I now have LE 9.0.5 003 Factory+ loaded on my MacBook Pro. Unfortunately, the other junk I have on the system is getting in the way and I am thinking of setting up a system exclusively for music.
Questions:
1. Any opinions on a new Mac Mini? How would you configure (memory, ports, etc.)
2. Can I get two instances of ProTools and just use my key when I work with either system. (I still want to be able to record with my laptop on the road.)
Any suggestions appreciated.
MOG
Michael O'Hara Garcia
Old 09-20-2013, 12:38 PM
Default Re: Apple Mini Recommendation
A Mac Mini i7 quad with dual 7200 rpm drives(or use an external FW drive for recording) and 16GB of RAM should be a little powerhouse! Those things can generate a lot of heat, so I would sit it on a laptop cooler. As long as both computers have the same version(s) of Pro Tools, just keep the iLok with you(unless you can afford a second iLok and license). You can install Pro Tools on as many computers as you like. It requires the iLok to open and run
Old 10-11-2013, 03:55 PM
jimlongo's Avatar
jimlongo jimlongo is offline
I'm running a 2.66 QuadCore i7 MacMini with 8GB ram and a Fusion Drive at home.
OS 10.8.5 with PT10/11 - it's fantastic.
I've heard that heat comment before, but mine is on 24/7 and it's cool to the touch (top and bottom).
Audio on an external FW800
noise | jimlongo
mini apple keyboard vs extended one capt kirk macOS 1 11-28-2011 11:44 PM
New Apple Mac Mini Server dr sound Post - Surround - Video 2 10-21-2009 03:34 PM
Firewire 410 Apple Laptop Recommendation??????? batchmister1 Pro Tools M-Powered (Mac) 3 06-03-2009 05:30 PM
Laptop recommendation for MBox 2 Mini???? JJshred 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-20-2008 01:58 PM
QUESTION ABOUT APPLE MINI soprano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-06-2005 10:13 AM
