  #171
Old 08-08-2019, 07:46 PM
Ghost In The Attic's Avatar
Ghost In The Attic Ghost In The Attic is offline
Default Re: NVMe upgrade for Mac Pro 4.1/5.1 Mojave
Adds to the trust, right? seriously, good that you got a working one
I am so glad it was a bad Crest. I really like the speed I am seeing. The crashes were a little anoying.
Retro 176 (pair), Pultec EQP-1A (pair), Germanium Comps (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL Fusion, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM92, PCM70... Amps, Amps & More Amps.
  #172
Old 08-08-2019, 07:51 PM
I know, right.. few months ago I was seeing random kernel panics but it appears I had a fuse going bad and don't have UPS here... it all sorted itself out when the fuse eventually needed to be replaced
  #173
Old 08-08-2019, 08:00 PM
It's the untracable problems that can make you insane.
  #174
Old 08-08-2019, 09:59 PM
arche3's Avatar
arche3 arche3 is offline
Yes, the directions are non-existant, but I did figure it out and was going to post photos after I got it up and running. Mine are parallel to the Crest. It turns out I did have a bad card. The new one is in and working beautifully. First thing I did was move a large file from one 970 on the Crest to the other 970. Bam, done. No crashes, PT working great.
Great news!
Sent from my SM-G975U using Tapatalk
  #175
Old 08-08-2019, 11:27 PM
WorldStudios WorldStudios is offline
So happy for you, Ghost, that you got it working. I dont believe that I got any screws with the Crest, which surprised me. There was a self adhesive pad in the lid, however, that keeps the drives in place. So I just used that one. Now I am worried that I need to get some screws after all. I did not get any printed instructions either. Nor any website address to go to.
Johan Bejerholm
World Studios
Sweden
Phone +46707773443
  #176
Old 08-09-2019, 04:01 AM
Here are some photos showing how the support under the ssd card should look.
One screw attaches into the brass riser from the back side of the card and the second screw holds the ssd card down.
I thought these things (the blades) needed a heatsink? If so could you post a pic or two of it and how it looks inside the Mac's card cage?
  #177
Old 08-09-2019, 05:00 AM
I wouldn't worry about it. In my 2013 trashcan Apple for some reason used heatsinked ssd's but any other brand I've used have omitted the heatsink and performed flawlessly.
I have no idea what kind of 24/7/365 100% stress test Apple has performed when they have found so much heat generated from ssd that they think heatsink is needed. After my hardest and longest stress test I can think of, opening the case and touching the ssd it is only lukewarm. I think memory runs hotter.
  #178
Old 08-09-2019, 08:33 AM
The pads are heat sink pads with adhesive on them. There is one on the Crest processor too. I know it is obvious, but be sure to pull the blue film off.
  #179
Old 08-09-2019, 11:23 AM
Thanks for the pics.
  #180
Old 08-09-2019, 01:01 PM
No problem. I should have posted them sooner, but I was waiting to make sure is was all going to work.
Mac Pro 2012 -should upgrade to Mojave? Zak7 macOS 5 06-04-2019 07:51 AM
Mojave? hanksinclair Artist Series 3 05-03-2019 03:19 PM
New 8th Gen i7 with NVMe m.2 SSD spock999 Pro Tools 2018 26 02-22-2018 11:47 PM
Bootable Thunderbolt case for NVMe drives (Samsung 950 etc) propower General Discussion 1 10-27-2016 04:11 PM
Intel SSD NVME/PCIe Porn Darryl Ramm General Discussion 0 04-03-2015 02:02 PM
