Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 01-04-2000, 04:29 PM
GROS GROS is offline
Default IS IT an absolute must to use scsi with mix running under 32 tracks
what type of errors are produced whith ide and mixplus configurations?
can this CONFIGURATION cause the system to occasionaly crash? G4/450 OS9 PT5.
this is a rephrase of a previously posted unanswered question.
STEVE?
Old 01-04-2000, 04:42 PM
Steve Rosenthal Steve Rosenthal is offline
Default Re: IS IT an absolute must to use scsi with mix running under 32 tracks
SCSI is required with all but PTLE/001 and PowerMix systems. (I assume that you are referring to the audio drive chani, not the system drive.)
IDE (as an audio drive chain) with Mix systems is untested and unsupported.
--Steve Rosenthal, Digidesign ETS
Old 01-04-2000, 06:03 PM
THANKS for your response.
Old 01-19-2000, 02:06 PM
Keith Lynch Keith Lynch is offline
Steve,
Well, I know IDE may be untested by Digi and unsupported, but I just wanted you to know that I have used the 10 g IDE drive in my beige G3 as a audio drive with a PT24 system for over a year without a single problem. If only the stuff on my SCSI / 9600 PTIII system would be so stable, my life would be wonderful. I know that technically the IDE isn't as good as SCSI, but it shure has worked for me. (I've recorded well over 100 sessions with this configuration with no problems) PT 4.3.2, 266 beige G3 96m, Sys 8.5.1
Running PT 64 Bit only yields 32 Tracks?? teacherman Pro Tools HDX & HD Native Systems (Mac) 23 01-16-2014 02:42 PM
LE running 32 tracks smoothly? DIGI could do it. sndchck 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-23-2006 01:54 AM
Running out of tracks! Please help BCole 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-23-2006 09:32 AM
HD-2 Questions - 96/192, SCSI, Tracks fmckinnon Pro Tools TDM Systems (Mac) 1 12-09-2002 10:04 PM
scsi or ide? 32 tracks eats my power.... tlester 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 08-12-2002 06:57 AM
