Old 12-23-2019, 10:38 AM
Sharkhaywood Sharkhaywood is offline
Default Re: Eleven Rack Is Now Only Putting Out a Clean Tone
Originally Posted by Darryl Ramm View Post
Sorry I am not sure what is going on. It's a bit hard to follow what exactly you mean. Is the amp block starting up disabled (and shows that in the Eleven Rack front panel display?). It might pay to do some more experimenting. e.g. a rig with just one effects pedal and nothing else. Does that work? Does it save/restore correctly? I'd do all those tests without the USB cable connected.
I think there have been occasional issues where the Eleven Rack gets confused and disables the internal rig monitoring, (so you hear nothing unless connected to a DAW). And there is a well know clock issue with old hardware that can stops all sound at some clock rates etc. Some folks using MIDI controllers run into problems with setup, misconfiguration or sometimes electrical signal problems switching stuff... make sure you are testing with any MIDI controllers removed.
Many other issues have been caused by just the complexity of all the rig settings, especially the multiple adjustable signal levels in a rig. One thing that can cause is "clean tones" if a level is pulled down, which is why I pointed that out before.
As jeffro asked... what rev firmware are you on? (esp. curious if you have been trying to operate the Eleven Rack editor with a pre-expansion pack unit... that won't work, but not sure of the problems it might cause).
I have a post-expansion pack unit. I am at work currently and will get specific details. Thank you to you and to jeffro for the help on this. I am thinking this will need to wait until after Christmas to deal with further because things are a bit hectic for me right now.
Eleven Rack Clean distortion ncmetalguitar88 Eleven Rack 5 09-15-2012 05:15 PM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Crackling and/or audible artifacts w/ Eleven Rack clean tones? wildstar Eleven Rack 50 02-23-2012 04:12 AM
The Tone Doctor Eleven Rack Mod tbub Eleven Rack 4 01-11-2012 04:53 PM
Clean Guitar Tone running direct KarNaL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-09-2007 09:16 AM
