Old 10-15-2010, 12:38 PM
RKrizman RKrizman is offline
Default Digi Expansion HD chassis no longer supported?
Holy smokes. Incredible that they're abandoning this piece of hardware, their own brand, while still supporting the Magma chassis. It wasn't that long ago that I bought the Digi chassis, which I chose precisely because I wanted it to be supported through upgrades.
This would be like Avid abandoning the HD interfaces but still supporting, say, the Lynx Aurora.
Am I the only one stupid enough to have bought this chassis and not unloaded it in time? Why in the world is there no upgrade path for this? Sorry if the outrage has already been vented--just now getting around to this issue.
-R
rickkrizman.com
Old 10-15-2010, 12:41 PM
Dism Dism is offline
Default Re: Digi Expansion HD chassis no longer supported?
-R
http://avid.custkb.com/avid/app/self...p?DocId=363039
The EOSS for the old expansion chassis came over a year ago, already.
I know it can be hard to keep up, but Avid is pretty diligent with keeping us aware of when they drop support.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
studiojimi's Avatar
studiojimi studiojimi is offline
i had Digi Tech Support on the phone tell me years ago to NOT buy that thing....I actually couldn't not believe that someone at Digi on the clock would say that but they did.
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 10-15-2010, 12:54 PM
dr sound's Avatar
dr sound dr sound is offline
Rick,
I use to have 2 of them but no more. They had issues. I replaced them with the PE-6R4-I Magma. It is rock solid, huge track counts. No problems. You can still use your chassis even though it isn't supported. When you can you should replace it with the PE-6R4-I .
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 10-15-2010, 01:25 PM
crizdee's Avatar
crizdee crizdee is offline
Its not supported beyond 8.0.1 there's no drivers for it so it definitely won't work beyond that.
PE6R4 is the way to go.
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-15-2010, 05:51 PM
uno1234 uno1234 is offline
This thing was garbage from the beginning.
But that being said, they finally worked out the bugs and now dropped support. I ditched mine before that.
It is pathetic that they would drop this, especially considering that it was specifically marketed as "future proof" because of the way the card connected to the chassis.
If this was Apple or Intel or a larger ("real") company, the lawyers would be lining up for crap like this. They misled their customers, offered them an unsatisfactory experience, then dropped the product. They should be ashamed. (Well actually, they are, I've received a few apologies from product reps).
Crap like this continues to make Avid/Digidesign a substandard company.
Old 10-15-2010, 08:44 PM
holden holden is offline
Originally Posted by uno1234 View Post
... They should be ashamed. (Well actually, they are, I've received a few apologies from product reps).
Crocodile tears. Not ashamed enough apparently to have the decency to offer an upgrade path. Having to spend an extra $2500 on a PE6R4 just to maintain the same functionality as the Expansion|HD has me rooting for Reaper.
PT9.0.0, 3.0GHz Mac Pro, OS 10.6.3, 13GB RAM, HD6/Accel, Magma PE6R4, PRE
Old 10-15-2010, 08:55 PM
I just don't get it. How hard would it be to offer a new set of guts to make it continue to work.
I'va always defended Digi in the past against the various naysayers, because I appreciate that they've provided an upgrade path to gear that actually gives you more processing power. But now, I'm in a position to have to upgrade my PCI cards and my chassis just to retain my current functionality.
A couple thousand here, a couple thousand there, pretty soon it adds up to real money.
-R
rickkrizman.com
Old 10-15-2010, 09:01 PM
WernerF WernerF is offline
It's hard to believe that this is news to anyone. Move along, there's nothing to see here folks.
Old 10-15-2010, 09:02 PM
Craig F Craig F is offline
it's ether Cards or Chassis not both
unless you want a HD6 PCIe rig
Thank you,
Craig
Digi HD|Expansion Chassis Depth ? Dutchmuzik Pro Tools TDM Systems (Mac) 2 02-06-2006 07:04 AM
UPGRADE MY DIGI EXPANSION CHASSIS ??? LKing Pro Tools TDM Systems (Mac) 8 06-18-2002 11:05 AM
longer cable for expansion chassis? venusmuzik Pro Tools TDM Systems (Mac) 1 03-20-2002 09:05 AM
digi NuBus expansion chassis niewielki General Discussion 3 07-03-2000 03:42 AM
Longer cable for Nubus Expansion Chassis? cander Pro Tools TDM Systems (Mac) 3 01-14-2000 11:30 AM
