  #271
Old 05-23-2011, 06:50 AM
kevinb511 kevinb511 is offline
Default Re: HEAT (Harmonically enhanced Algorithm Technology)
I downloaded and installed the demo version onto my HD2 system, and I see it load as I launch Pro Tools (8.1.1) but it is nowhere to be found. Went into the options menu to turn it on, but the option is not there. Also does not appear in my mix view options. Anyone else having this issue?
PTHD 8.1.1, ASUS P7P55D, Intel i7, 4GB Ram, 2x Nvidia GeForce 9500, OSX Snow Leopard 10.6.7
  #272
Old 05-23-2011, 07:29 AM
WernerF WernerF is offline
Did you download and install the iLok auth?
  #273
Old 06-14-2011, 10:36 AM
Djehuti Djehuti is offline
Originally Posted by kevinb511 View Post
I downloaded and installed the demo version onto my HD1 system, and I see it load as I launch Pro Tools (8.1.1) but it is nowhere to be found. Went into the options menu to turn it on, but the option is not there. Also does not appear in my mix view options. Anyone else having this issue?
I assume you figured this out, but you have to show the HEAT area on the right of your Mix window by clicking the little "|<-" indicator in the lower right corner.
From there you can turn it on and access the controls.
  #274
Old 06-17-2011, 08:44 AM
Actually never did figure it out, just gave up. It doesn't show up as an option in the mix window. I am running an HD2 PCIX 8.1.1 system on a self build Mac. Just chalked it up to incompatibility with that set up. Still trying to figure out how to update my signature
  #275
Old 06-22-2011, 03:41 PM
Default
PCIx means not Intel, which explains it. HEAT is not available on PowerPC (G5).
  #276
Old 06-22-2011, 03:59 PM
manichouse manichouse is offline
Not true. HEAT on Windows 7 with PCI-X works fine and is supported. Also works on Snow Leopard / home-grown Macs with PCI-X, though that combo is obviously not officially supported. People seem to forget that PCI-X HD cards can actually still be purchased new.
Martin Trum
  #277
Old 08-05-2011, 02:54 PM
tarfungo tarfungo is offline
Originally Posted by jpd52 View Post
Someone please enlighten me as to where to adjust HEAT from?
Braindead,
Thanks,
Jon
[email protected]
A direct email would be more than welcome..
Jon, Check this vid - http://tinyurl.com/44gp8l7 - specifically starting about 0:55 seconds. I'm not affiliated with the producer of the vid, just found the vid helpful when I first installed HEAT.
  #278
Old 01-18-2012, 02:25 AM
optical.highway optical.highway is offline
Default HEAT free installation?
Hi all,
I purchased an installed PT 8HD last september but didn't get the option to install HEAT. I wonder if the reseller sold me an old copy before the free offer for HEAT. If I can prove I purchased PT8 last September can I stil get the free HEAT offer?
Adam.
  #279
Old 01-18-2012, 02:45 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: HEAT free installation?
Originally Posted by optical.highway View Post
Hi all,
Adam.
Was this a new HD core system you bought? hardware and software?
Chris
Producer, Engineer,
www.ukmastering.com
  #280
Old 04-03-2012, 08:51 PM
Keith Robichaux's Avatar
Keith Robichaux Keith Robichaux is offline
Originally Posted by crizdee View Post
Chris
So Chris a new Hd1 purchase do you get Heat? Also if you buy new hd1 with 8HD or 9hd do you automatically get 10?
Thanks
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 10:17 PM
9.0.2 crashes when setting X-Form algorithm A Chapman macOS 3 03-22-2011 08:38 AM
Melodyne algorithm unhappiness thread kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-26-2009 02:28 PM
Rhythmic algorithm Steve MacMillan Pro Tools TDM Systems (Mac) 3 11-28-2007 10:44 AM
positional scrubbing algorithm? KingTor Pro Tools TDM Systems (Mac) 0 06-05-2000 01:04 PM
