expansion chassis weirdness
i just installed a digi 7-slot expansion chassis.
i have the expansion card installed in the first available PCI slot (after the graphics card which takes up the space of the first one) in the G5. i have a digi core card in slot 1 of the chassis followed by 2 process cards. the strange thing is that i could not get protools to recognize the audio interface until i hooked up the digilink cable to the 2nd process card. as far as i know it should actually be hooked up to the core card. i tried reseating all the cards as well as the FlexCables but it didn't make a difference. also, i couldn't even boot the system when i installed a new firewire card (Pryo PCI 64) in the PCI slot following the expansion card on the G5. i was wondering if it should actually go in the chassis instead since that would be the backwards way to do it and that seems to the way things are working right now! the reason for the chassis is to be able to use Mojo with the 2nd firewire card. also, PT was working fine with the previous setup minus the chassis. ideas anyone? CPU Type: PowerPC G5 (3.1) Number Of CPUs: 2 CPU Speed: 2.7 GHz Mac OSX 10.4.2 ProTools v7.2 |
Re: expansion chassis weirdness
Perhaps try the Pyro card in the G5's third slot (which is the fastest). You might also have an issue with the expansion chassis, host card, or connecting cables are defective. Lee Blaske |
...also make sure you follow the "Power Up" procedure as described in the Expansion HD manual. It's crucial.
First: Expansion Chassis Second: External clocking (if you're using it). Third: Audio Interfaces. *Wait until interfaces are fully booted (LED's stop flashing)*. Last: Computer. "Power Off" procedure is the reverse. |
Mac Pro Early 2009 3.06 Six Core 48gb ram, Pro Tools 10.3.10, HD6 Accel, Pro Tools 2021, Macbook Pro, Magma PE6R4i, Yamaha DM2000 Console, Logic 9 and 10, Apogee Big Ben, 10pcs HD 192's, Benchmark DAC-1, Distressors, API, Neve, Rupert Neve, Dangerous, Lynx, Manley ELOP+, Massive Passive, VariMu, Neumann, Peluso, A-Designs Hammer 2 & Nail, Empirical Labs, Drawmer, Lexicon U87, Bricasti M7, dbx, Cranesong, SSL 500 G-Bus, Custom Audio Germany, Dynaudio, Focal, Yamaha, TC Electronic, Mapex Drums, SPL |
Expansion Chassis VS 64 Bit Chassis Latency | Touchwood Studios | Pro Tools TDM Systems (Mac) | 2 | 08-09-2006 05:03 PM |
Digidesign Expansion|HD Expansion Chassis work ok? | Will Russell | Pro Tools TDM Systems (Mac) | 8 | 05-25-2006 02:19 PM |
ATX PS for AT expansion chassis? | guitarmn | General Discussion | 0 | 03-11-2002 04:50 PM |
expansion chassis | kevdrm | General Discussion | 0 | 10-15-2001 07:22 AM |
Card order weirdness - Bit 3 chassis | smirky | Pro Tools TDM Systems (Mac) | 7 | 02-27-2001 12:28 AM |
