Routing USB Audio into HD?
I guess this is semi-pro?????? but has uses. So a PODxt has USB out, and that's the only way to record with it digitally (the non-rack mount PODxt). I can record into Audio Hijack, but it'd be cool to route it into PT. Maybe there's a plug-in that can access a USB device & route it in? Any other thoughts?
Re: Routing USB Audio into HD?
Unless someone has written a re-wire app or vst that you could rap I think you are out of luck.
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
On way(possibly) is to use a program called wire tap,its free. It records any sound digitally that is routed to the mac outputs.
e.g DVD player or a pod. so you could play a track on PT play through your pod,record it with wire tap and then import the audio file into PT(youd have to sync manually though). That should work though a bit of a faff. |
MP9 audio routing | CharlesTwist | Pro Tools M-Powered (Win) | 0 | 04-10-2012 03:53 AM |
Routing audio out of PT, back into PT?? | Obe1 | Windows | 2 | 05-29-2011 07:37 AM |
Routing Mac audio into PT | RobRaden | Pro Tools 9 | 6 | 11-18-2010 10:10 AM |
003 Audio Routing help Please.. | pguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-16-2008 09:44 PM |
Routing Audio | E-Buzz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-12-2005 05:12 PM |
