Old 02-05-2001, 12:20 AM
GW GW is offline
Default Midi Port PTLE 5.01
When I import General Midi-files into PTLE 5.01 for Windows, all portsettings are altered to No 1 (Digi001) and ignore all others. Have I overseen something?
Göran
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8,
Digi002 Fact., Logic X|FCPX|Motion
Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune
VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile
Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix
Old 02-07-2001, 08:26 AM
DigiTechSupt's Avatar
Default Re: Midi Port PTLE 5.01
-As far as I know, the Std MIDI File spec only supports Channel (maximum of 16) assignments but does not support Port assignments.
-Type 0 files contain all MIDI data for all channels on a single track
-Type 1 (multitrack) files are contain MIDI channel data on different tracks.
Brent
Avid Audio Tech Support
Support FAQ
Old 02-07-2001, 01:14 PM
lwilliam lwilliam is offline
If I recall correctly, all of the SMFs I've imported are automatically assigned to the "default" port in OMS - whether that's port 1 or port 8. Because of that, I've assigned my "default instrument" to a GM module so I can at least audition the file quickly.
Don't know about PeeCees, tho'.
LW
Larry
PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins.
Midi Controllers - Midi Port Assignment eneezy1 Pro Tools M-Powered (Mac) 1 08-15-2012 08:44 PM
Midi Controllers - Midi Port Assignment eneezy1 macOS 4 07-30-2012 02:40 PM
PT9 + Mbox3 Pro Midi Port question + RTAS midi routing mrwolfe macOS 0 05-29-2011 11:24 PM
unable to setup MIDI instruments through Mbox 2 Pro MIDI port tomazbevilaqua 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-30-2010 06:04 AM
Digi 002R Midi Port 3 in Midi Studio set up hwsf12 MIDI 1 02-17-2010 09:10 PM
