  #51
Old 07-21-2016, 10:48 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Eleven Rack Editor - Info
Originally Posted by Edwoods View Post
Yes The Editor is installed.But all it gives me is a small image of the 11r that says hardware connected and sample rate. I was on Win 7, all was well ,Downloaded free Win 10, Didn't like it, Rolled back to Win 7.This is when the problems started. This is what I'm looking for http://connect.avid.com/eleven-rack-editor.html. But I don't ger the stand alone Editor! I must thank you again for your help, Eddie
It sounds like you are clicking on the Eleven Rack driver, that is not the editor.
You want to open the ELEVEN RACK EDITOR, not the Eleven Rack Control Panel.
If you are not seeing "Eleven Rack Editor" listed in your start menu, then you need to install it.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
  #52
Old 07-26-2016, 04:42 AM
Edwoods Edwoods is offline
I got it to work on my Laptop. Thank you for your help,Eddie
  #53
Old 07-29-2016, 05:21 AM
craigny craigny is offline
Just a question here....so I installed the latest drivers for my 11 rack (bought it used)....then I installed the stand alone editor....the first time I got the message that the Microsoft Visual C++ 2010 did not install.....it didn't complete the install.
after the first attempt I saw the icon for the iLok manager appeared....I then tried to reinstall the editor again and I got the same message about the Visual C++....I clicked continue and it went forward with the installation.
after completing the install I now have the icon for the editor, when I connect the rack the computer picks it up, the control panel is available and when opened shows its connected....and the editor opens and appears to work as it should.....am I good? Would the fact that the Visual C++ may not be installed affect anything? Like I said the editor seems to be working fine?
  #54
Old 07-29-2016, 01:46 PM
Benoni's Avatar
If it's working don't worry about it. I've had that error before but don't remember what caused it... Do you have Quicktime installed? Is the iLok License Manager installed? I think not having those could cause that but don't remember because it's been a long time.
If you want to look further into the C++ error if the above doesn't fix it you could try this https://www.microsoft.com/en-us/down...s.aspx?id=5555
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
  #55
Old 07-29-2016, 04:23 PM
Sorry for the delay...ive been too busy downloading your AWESOME rigs!!!
The editor is working fine it seems....I do have the ilok manager icon on the desktop but haven't had to use it...also I have quicktime from my apple software....I tunes....the ilok manager appeared after the first failed attempt so maybe that did it...like I said im downloading and using the editor....should I even bother with the Microsoft link?
  #56
Old 07-30-2016, 09:50 AM
Benoni's Avatar
No. Unless you are constantly getting the error don't worry about it.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
  #57
Old 07-31-2016, 06:53 AM
Thanks!
  #58
Old 08-02-2016, 03:43 AM
another quick question. Im upgrading my computer this week. going to be running windows 10....I know the latest Eleven Rack drivers are listed to support. Any expected issues on the editor for Windows 10?
  #59
Old 08-02-2016, 06:07 AM
JoelG's Avatar
JoelG JoelG is offline
Working fine here with Win 10!
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
  #60
Old 08-02-2016, 12:53 PM
Benoni's Avatar
Joel
same here.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Eleven Rack Standalone Editor brianiac5150 Eleven Rack 315 02-07-2015 04:53 PM
Eleven rack editor freezes baribari Eleven Rack 2 02-17-2014 07:40 AM
Eleven Rack Editor Now Available Avid Technical Alerts 0 01-23-2014 09:02 AM
