Old 04-03-2015, 09:32 AM
john1192 john1192 is offline
Default Extra Long Delay - Why Avid did you discontinue ???
i just had to open several older sessions and the Extra Long Delay is boning my world ..
i just wanted to say THANK YOU NOT AVID for discontinuing this plugin ..
is there any way we can get it back .. i have dozens of session that i used this as an effect and now need to re-build these track FX .. Lame IMHO
flame on at me .. i do not care anymore .. i can open a session in cubase from 1857 and it will all work ..
you are losing me Avid, one day at a time .. yesterday i fired up PT11 on my macbook pro and Assertion errors and have to toss pref's - we are all getting tired of resetting every pref we use on a regular basis .. such lame lame BS from the "Industry Standard"
no cheers today .. john
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 04-03-2015, 11:23 AM
bashville bashville is offline
Default Re: Extra Long Delay - Why Avid did you discontinue ???
The Mod Delay III is the replacement for that, and it includes some presets based on the starting points from that old series of plugs. It goes up to 5000 ms and replaces the "short, slap, medium," etc. series and puts them all in one plug. It also has the updated look similar to Channel Strip, and the new Revibe.
For me, I found the old series to be kind of a hassle, not always knowing which one to grab for whichever delay length. They must have given you a choice for when DSP and CPU power were at a premium.
The transition period can always be a hassle, and it's too bad it won't automatically open the older ones in the new format; but I actually like the new plug better, having it all-in-one.
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur
Old 04-03-2015, 12:45 PM
Agreed, but from what I am told, the delay plugin in 12 actually will open with settings from the old delay plugins, so its only us PT11 users that have to swap for the new plugin and enter the settings we want.
Old 04-03-2015, 01:01 PM
Drew Mazurek's Avatar
I'm still trying to figure out this need to open old sessions?? I make records, they are released, and then I make new ones, with new clients. I rarely go back to old sessions. And when I do, I (sometimes foolishly) think I can make it better anyway and end up changing all sorts of things.
www.drewmazurek.com
Old 04-03-2015, 11:38 PM
You mean if I open a former PT10 session with "Long Delay" inserted, that it automatically instantiates Mod Delay III with the correct setting preserved? That's cool--although like Drew says, once you get past your transition projects, you're in the clear with the new plug, so no angst from there forward. Nice to hear, though. Ya never know!
Old 04-04-2015, 06:57 AM
YYR123's Avatar
YYR123 YYR123 is offline
Im glad I'm not the only one, it's like trying to perfect the wheel it just keeps getting rounder and rounder, better? Meh?
Daniel
Old 04-04-2015, 07:05 AM
JFreak's Avatar
JFreak JFreak is offline
The different delay plugs were TDM load optimisation back in the day. Shorter delay plug demanded less DSP than extra long delay. There was a time you really needed to think about resources. Which is why there also was multiple EQ plugins. And which is why for example Sonnox EQ has different variants, including "filters only" version of their plugin.
Today, we can just forget that. Plenty of processing resources. Too bad backwards compatibility suffers, but that's called progress :)
Janne
Old 04-04-2015, 12:35 PM
hi Drew, the reason is this .. i have an opportunity to have a few songs, from a Record (CD) i worked on a few years ago, to be used as a Multi-track DEMO for a 5.1 system at a trade show - the tracks will live in a Joe Co blackbox Recorder / with PLayback Software feeding a Console via MADI - they want my mix to be able to push up faders to Unity and there it is (i mix like that so it should be fine - they can slap on whatever 2-bus processing they have in the console to show off that portion of the console).. assign some fun 5.1 (FX and such) .. they asked me for Dry Stems and FX Stems .. All i wanted to do was open the session and bounce out the FX stems .. has been an ordeal of re-loading PT10 on another 10.8.5 partition .. now i got the Extra Long Delay's for 2 tracks bounced out ..
BUT !!! it has opened another can of Worms .. Space .. (not TL Space) not working in 10.3.10 .. my session say SPACE is in the AAX plugin folder BUT i think it is because PT10 cannot access 64bit ONLY plugins .. ALSO: i believe when you get SPACE Avid takes your TL Space License, so now when I try and open an older session to get the REVERB stems SPACE is there but greyed out and TL Space cannot be authorized ..
YES, i can and probably will have to recreate the SPACE tracks .. Good Thing it is only a couple songs and not the entire Record
I was just trying to make my life easy this weekend .. a little BBQ and bouncing tracks out for this .. and been hours try to solve this already .. THX AVID .. can no one over there Think Ahead !!!
cheers john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 04-04-2015, 12:55 PM
Makes sense. I suppose you can always come up with a reason NOT to progress, but as Janne pointed out, there were legitimate reasons for the change.
Hey, at least you're not having to recall an SSL console and reassemble all the outboard gear!!
www.drewmazurek.com
Old 04-04-2015, 01:06 PM
cheers john
Actually now that I begin to see it in terms of lost BBQ time I think I see his point...!
cheers
Click, D-verb, Extra Long Delay II, Short Delay II are missing in PT10 UPGRADE ruxandra Windows 6 06-20-2012 05:29 PM
Where Did Extra Long and Short Delay II Go? Trailerman Pro Tools 10 6 01-18-2012 01:57 AM
Extra Long Delay BUG!!! Now With Picture To Prove It!!! M2E Pro Tools TDM Systems (Mac) 6 08-12-2007 10:18 PM
DIGI, PLEASE FIX EXTRA LONG DELAY BUG.....! M2E Pro Tools TDM Systems (Mac) 0 07-29-2007 02:40 AM
Plugin Sharing Bug!!!! Extra Long Delay M2E Pro Tools TDM Systems (Mac) 12 07-08-2007 05:50 AM
